Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: portable electric winches
    Feb 2009
    There seem to be quite a few reasonably priced 5000lb portable electric marine winches, and I'm wondering whether one with some synthetic rope and a snatch block could be handy for swapping between the work ute to the D4.
    I think the weight would be similar or less than a Tirfor?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Moruya Heads/Sth. Coast, NSW
    Unless you anchor the portable winch to a tree (anchor point) you will need at least 2 snatch blocks, Regards Frank.
    Feb 2009
    Quote Originally Posted by Tank
    Sorry to be the novice I am and ask the obvious question Frank, but (and this may go for hand winches too), why can't you hook the winch to the car's recovery point? Thanks
    No problem, but if you want to get a mechanical advantage (MA) of 2 then you need the snatch block attached to the vehicle and the winch anchored to a tree or anchor point. MA is calculated by the number of ropes supporting the MOVING block (snatch), so with the snatch block connected to the vehicle you are gaining a mechanical advantage. There is no MA the other way round, works good for tirfors as well, if you wish I can PM you the riggers guide, regards Frank.
    I wouldn't mind a copy of that riggers guide Frank!
    On the subject, I reckon its only a matter of time before portable winches get strong enough and light enough to add to a recovery kit and not cart around on the vehicle 24/7.
    Judo's Avatar
    Judo is offline ChatterBox Silver Subscriber
    Feb 2012
    Parkdale, Melbourne
    x2 on both points!!
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Jul 2010
    Sydney/Balmain
    Quote Originally Posted by Tank View Post
    Correction here.
    If you put the snatch block on a tree and run your winch wire off and through the snatch block and back to the recovery point on your vehicle you gain a 2 x reduction. ie if you have a 5000lb winch in theory you have 10000lb pulling power.
    Didge Guest
    From my readings it doesn't seem to matter where the pulleys are attached as long as the configuration is correct
    Feb 2009
    Thanks Frank, I think I saw a link to the guide in another thread?
    Feb 2009
    Quote Originally Posted by DT-P38
    These 5000lb marine winches weigh less than 20kg, apparently... It would be great.
