Results 1 to 4 of 4
Thread: Handbrake Mechansim Return Spring
    Mar 2009
    Near Geelong, Vic.
    I neglected to take a photo when I dismantled so I can't determine how this spring attaches:
    The eyelet @ the bottom is self explanatory but where does it attach @ the top?
    Surely it's not this notch on the lever? That's one HELL of a stretch!
    The spring is a bit on an overkill anyway IMHO!
    Cessnock NSW
    There should be a small tab off one the T case gearbox mount the spring attaches to it, can't post a pic ATM, but I am sure you will remember how cheers Dennis
    Mar 2009
    Near Geelong, Vic.
    That makes sense now!
    Yes! T'other end MUST go to a stationary point off the mechanism.
    This is a different gearbox to the one I removed and it has no such tab. I shall go & ferret out what I need.
    Cessnock NSW
    Handbrake anchor point
    This is what you need
    http://i659.photobucket.com/albums/u...0/ffdcfb44.jpg
    Hopefully you will find yours, if not you could easily make one, cheers Dennis
