Results 1 to 10 of 16
Thread: Puma head unit
    Jan 2010
    Exmouth/Tom Price
    Puma head unit
    Hi guys,
    Some time ago there was a thread on defender stereo head unit and the adaptor thing that fits into the original wiring.
    I have tried to use the search button with no luck can any one tell me what stereo they have fitted with USB for iPod .
    Dan
    Safety Bay
    I fitted a Phillips stereo to mine,took 5mins to fit and cost $179. Pat
    Perth, WA
    Hi Dan, I fitted a Parrot Asteroid which was great till it died I've replaced it with a Pioneer unit. For the wiring you need an ISO to <stereo brand you buy> adapter, this should be readily available at a car audio store.
    Tim
    May 2008
    Horsley Park, Sydney
    Like Tim said, the Puma is fitted with an ISO socket / plug, so what ever radio you get will either an ISO plug / socket or a patch lead to suit the radio you buy. There are quite a few different radios with ISO plugs and front USB plugs available.
    The likes of Jacar sell both radios with ISO sockets or patch leads for some other radios.
    Erich
    Jan 2010
    Exmouth/Tom Price
    Thanks guys,
    I will look at getting a pioneer unit.
    They seem top have the iOS harness available off the shelf.
    Dan
    Safety Bay
    Dan,stereo shops have the adapter and it's a simple plug and play. Pat
    Nov 2011
    I picked a pioneer unit with everything it, and bought the adapter from Supercheap for under $15, only problem was that they had 2 different connectors for the Pioneer unit, so you just need to know which connector your stereo, or do as I do and take it back and swap it for the correct one.
    This was by far the easiest stereo I had ever installed, didn't even need the soldering iron.
    Richard
    Yep pioneer here as well
    Nov 2008
    seaham (gods country) nsw
    If you just want the usb connection and nothing extra, just get an FM transmitter, dont have to mod anything, can play whatever you want through the built in system. Mine follows me from car to car and charges my iphone at the same time. costs about $70 from JBhifi or DS.
    Perth WA
    I went with the JVC AVX-77. nice little unit, not sure if it is still available. here is a link with the install.
    New Stereo and Compressor for my Puma
    The plug I used was something like this
    PC2-36-0 Female ISO Bare End Adaptor Wire Connector | eBay
    hope this helps
    Craig
