Results 1 to 9 of 9
Thread: HP Desktop with Vista - Should I just blow it up?
    Poland (I kid you not)
    Just seen this part of the forum and have a really curly question
    My computer is an HP s3460a desktop running Vista (OK, not really running).
    It froze (no surprise) so i had to switch it off and on again.
    It did not power up, there are no beeps, however the lights come on and the fan spins.
    I've tried:
    reinserting the ram
    connecting to a different monitor
    resetting the CMOS
    Praying
    I have never had much luck with HP, and I'm guessing it could be the power supply? Can anyone help?
    Jonathan
    Avoca Beach
    If the lghts and fan are coming on, the power supply is OK.
    I suspect the hard disc has died. Have you tried booting with a recovery disc?
    Have you removed the battery completely,waited , then reinserted it, without being plugged into the charger.
    Regards Philip A
    Nov 2008
    seaham (gods country) nsw
    kill it.... kill it with fire, then get something with win7 or OSX lion
    Kootingal
    It sounds as if it the BIOS doesn't pass the POST (power On Startup Test). That means get a new 1
    Last edited by Banjo_pluker; 11th June 2012 at 02:39 PM. Reason: POST meaning was wrong, bloody phones
    Regards Philip A
    Hi there
    yes, removed battery, also reset jumper on motherboard for CMOS: nothing
    Don't think it's the hard disk as there is no power-up beyond lights and fans spinning
    Quote Originally Posted by Banjo_pluker View Post
    It sounds as if it the BIOS doesn't pass the POST (power I. Startup test. That means get a new 1
    This sounds right - does this mean it's cactus or can it be repaired?
    Kootingal
    Quote Originally Posted by poleonpom View Post
    Depends on the motherboard and weather you can access the bios, I am shuming you can as you can reset the CMOS,
    After rereading your original post which fan comes on, is it the power supply fan or both the computer fan and power fan power should be ok. It does not sound like power failure of the computer would have shut down and not just frozen
    When I googled your model, support pages were not available for that model so it may be discontinued.
    At the cost of computers these days, especially if you can build your own (if you can reinstall ram you have the skills, it is that easy these days) they are so cheap it may not be worth trying to fix
    Sep 2006
    Melb.
    Hi poleonpom - I'm in Aspendale Gardens if thats not too far your welcome to bring it down and i'll take a look for you. I got some time at home at the moment.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    my money is on the power supply
    got a multimeter?
    try the voltages on a 4pin molex plug
    if below 12v or 5v you need another power supply generally speaking
    lights and fans working is no indication unfortunately...
    ATX Computer Power Supply Pinout and Connectors
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
