If it's the same spec as your car, grab it.
If it's not the same spec & you have a HSE, then some of the mechanical bits are not the same (different gearbox, rear diff) so you need to weigh that up.
Greetings all
I have been offered a P38A in reasonably good condition but with a damaged engine for a $1000, I am not sure what the air bags and HVAC components are like as I can't start the engine, while my vehicle requires a few parts it certainly does not require some of the ones that are on this vehicle.
My query is, do you think the price is OK and should I purchase it as a ready source of parts for mine if needed, storage space is not an option.
Best regards and thanks in advance
David![]()
Put your location in your profile so we can see where you are. Someone close to you may be able to go halves with you. Like me.
Now: 2005 L322 Vogue 4.4 M62TU (Black)
Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
Sounds like a good buy, and your a little bit far from me but not too far - whats the problem with the motor?
2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
and a Nissan Cube............
South Australia.
