Results 1 to 6 of 6
Thread: Sagging front end
    Jan 2011
    Newcastle
    Sagging front end
    I was wondering whether those with steel bullbar and winch fitted have noticed lower posturing of the front end afterwards. I'm convinced it is sitting 1-2 cms lower at the front. The tape measure seems to agree. I drive a MY11 D4 HSE.
    I thought the air suspension should be albe to cope with extra weight (estimated to be 80kg) given the rear end can cope with 350kg additional weight with a trailer attached.
    Regards Trif.
    Feb 2010
    Mount Martha
    Quote Originally Posted by trif View Post
    Regards Trif.
    Hi Trif,
    Had my OL bar on for 18 months now. Didn't notice any difference when fitted, and don't now.
    Cheers, Craig
    mandurah
    It will adjust back to where it was automatically. If you want to trim it up a bit, you will need to invest in a Faultmate. There is quite a variation ( I think + or - 25mm ) available to 'finetune ' the std height settings. I have adjusted mine up about 10mm with a Faultmate.
    D4 2.7litre
    Apr 2011
    Coffs Harbour
    As we get older all the front ends sag
    Mar 2012
    Gabbadah WA
    Quote Originally Posted by Plane Fixer View Post
    Rear ends tend to sag a bit too !!!
    Jan 2011
    Newcastle
    Thanks for the input guys. For the record l was referring to the cars front end, not my personal front end .
    I've spoken the local LR dealership and they'll run the computer over it next week and 'recalibrate' the height sensors. A faultmate is sounding better all the time ............
    Regards Trif.
