You want a fixie?
my eleven year old avanti has served me well.......
i'm right back into commuting to work......
i kinda want to upgrade but there isn't really anything wrong with the avanti.....
sooo, i was inspired by the style over speed ride in brissy friday night on seeing a few custom single speeds. i thought it would be good to mix up my ride to work on a single speed......its a flat ride, on a still day i only change gears a handful of times.
sooooo who has converted a nine speed to single?
i read one one website they encourage new comers to SS to consider a fixed hub......umm this sounds interesting in peak hour traffic and going down the couple of hills at 50km/hr
looking for ideas, de-badged bright paint job is the minimum
my next question will be what will be my next roadie.........
You want a fixie?
Slunnie
flip flop hub is the go.... best of both worlds ;-)
How does this work??Originally Posted by EchiDna
The hub has a fixed sprocket on one end, and a freewheeling sprocket on the other, you turn the wheel around to change from one to the other. You will probably need some sort of chain tesioning device as well, due to the different angle the wheel slots are for the 9 speed. ie. open to the bottom rather than open to the back. If you would like to try out the joys of a fixie, i have one that you could take for a ride, it has no brakes though, it is a track bike. Fixie riding I feel is cycling in its' purist form.
Cheers, Mick.
1968 SIIa SWB
1978 SIII Game SWB
2002 130 Crew Cab HCPU
Plenty of kits out there to do it, spacers, slip ring and a tensioner.
Would I ride a fixxie in traffic, nup. I rode track which is all fixed wheel for a few years and still wouldn't do it.
IMHO riding a fixie for commuting is less than sane.
I have a couple of dozen stiches in my foot from an excercise bike that was essentially a "fixie"...
I built a single speed up out of an old steel frame. I used a kit to turn some old conventional road wheels into a single speed, so it can free wheel. I have brakes front and rear, for safety. Cell bikes do cheap single speeds. Your next road bike will have to be something Italian, might I suggest Colnago?
JC
