Results 1 to 10 of 13
Thread: good idea, doing it the crazy way!
    Jan 2011
    Burpengary, QLD
    hello people,
    I recently asked if getting a disco as a daily driver was a good idea or crazy, you were all kind enough to put me right and I'm now going to look at a 96 300tdi manual with engine issues ( I never seem to do anything the easy way ), there is apparently a knocking from the front of the engine low down, I'm prepaired for a rebuild as my only option and I'm lucky enough to have some good mates willing to help and a man who can do these things for cash.
    what other things should I be looking for on the car, and if a rebuild is needed what other things would people suggest I get done at the same time, I figured timing belt, head gasket and clutch were no brainers but are there any more 'rover specific' things to do whilst its apart?
    as always I'm indepted to you all
    thanks in advance
    I guess the first question is how many K's on it? But if you're going to rip the engine that far might as well throw rings and bearings at it.
    Steering box is easier to do while it's out as well if necessary. Check for leaks at the lower side of the shaft.
    Jan 2011
    Burpengary, QLD
    240 odd thousand on the clock, the seller admits he's no mechanic ( I know how that feels) but thinks it might be big end bearings, I will be taking a mate with me who knows about such things, I'm a welder.
    will the steering box just need checking for leaks or are there any other tests I can do, engins still runs, just knocks if it revs
    Douglas Park, NSW
    Hmm, knock low down at the front.....I wonder if the harmonic damper has come loose on the crankshaft.
    If the bolt is not done up super tight after a belt change, the damper/pulley can move on the crankshaft, flogging out the keyway & sometimes damaging the crankshaft too .
    Adelaide - Torrens Park
    That was my first thought too.
    St Helena,Melbourne
    4.28 MB
    Unless its dirt cheap why go thru the headache of buying a dunger where there are plenty of good vehicles available that dont require a rebuild ?
    You say you are no mechanic so save yourself some grief.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2010
    tom price the pilbra, west aust
    times 2 spend your well earned dollars one a car you can enjoy straight away, not something that requires hard work and tears plus more money straight away
    South Sydney
    If it needs an engine rebuild it's worth less than a grand, seriously, good D1's are only about 6k, personally i would look for a good one, mind you i rebuilt mine when i drowned it.
    Jan 2011
    Burpengary, QLD
    history as far as I know, is that the car was running fine then was put in a barn after the owner got a work car, 8 months later he decided to sell so charged the battery, started it and left it to run for a while, 20 mins later the knock started from the front of the engine, he thinks the usual land rover oil leak might have dropped to much and it suffered. If the thing is only worth a thousand then thats what I will pay tops, don't mind a project, actually the idea of learning the mechanics on the job is one of the reasons for doing it.
    I've been looking for a disco for a little while, trying to find a manual 300tdi is not as easy as I thought, there aren't any in Qld at the moment and at least if I do the work I know what I've got when I'm finished.
    South Sydney
    I wonder if it's the oil pump then???? Have you looked at the level?
