If your winch has a wireles remote the get an isolator as the receiver is always draining a little bit of power they are good idea if your winch fries it self and gets stuck on you can turn it off at the isolator
New tigerz11 12000lbs on the D3. It comes with a power isolator on the positive lead. I could not get this from the winch in and was reluctant to break the water tight seals on the control box to drag in from the battery back to the winch.
Managed to break the isolator switch trying to get it in the same location my prior winch power supply came into my grill from.
The isolator which came with the Tigerz winch and I broke is not a type I can find here. See pictures. I can buy a replacement cable or simply join the cables without the isolator. It seems a good design but I am wondering if we need a isolator on our winch’s or not. Pictures are not from my truck.
Last edited by NavyDiver; 19th June 2012 at 03:31 PM. Reason: Pictures are not from my truck.
You MUST have a power isolator somewhere,
I use one of these
http://i.ebayimg.com/00/s/MTQ3NFgxMzQy/$(KGrHqZHJBwE8fT!hE8-BPPGEJ1zdQ~~60_35.JPG
look up 'winch vandals' on google
Ive heard of cases where vandals have unspooled the cable , put over the top of a car onto the tow bar, smash the relay box & set the winch going, thus squashing your roof flat or cutting your car down the middle,
I wonder if the second hand stories about cable vandles might be a little off. Know of a few specific instance including a policeman deerhunters car (hope the poachers are still in jail)The media would cover if a car was chopped in half I imagine. Your right that many control boxes cables are interchangable so it is a risk. Not all interchangable thankfully.
A sparky mentioned the volatage drop associated with the isolator type you posted as possibly a little high for winching. Any cable break or join is a weakness of course. The copper to copper conection in the very basic isolator I broke seemed a very good design to minimise any volatage loss or imeading any current further than the cable alreading introduces.
Those isolators are good for 300 A , 1000 A surge.
You don't need any controller if you get the cover off.
Sent from my ZTE T28 using Tapatalk 2
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberI use a Narva 61060 dual pole switch.
Battery Master - Products - Narva
It is dual pole rated at 250 Amp continuous per pole (1250 Amps per pole short term). I commoned the two power out contacts with a brass bar and connected this to my winch.
The inputs I connected directly to each of my two batterys. This configuration gives me an in spec. 500 Amps continuous to the winch, or a massive 2500 Amp short term, in practice it runs my 12000 lb Warn winch no problem.
This gives me winch isolation when 'off' and makes battery coupling a certainty via the switch and not via an overworked under current solenoid or other device. It also allows easy battery coupling when needed. When off the switch key can be kept elsewhere for further security.
Whan I bought mine 2 years ago it was around the $70 mark.
A tick in every box.
Deano
The local auto lec suggested I install one due to the chances of the winch vandal trick, which he showed was easy with my winch setup.
Don.
Food for thought. I have no isolating switch but a heavy pair of side cutters in the car to cut the winch power if ever needed. I wonder if anyone has ever had to cut the power using their isolator switch because of a short or the winch stuck on? I suspect that this is a very low probability event but interested to hear experiences.
 ChatterBox
						ChatterBox
						I agree with going bush, dad and his father sold Land Rovers for many years and experienced quite a few instances of this 'crushing of cars' on the 4wd scene. I recently fitted an old Warn we had laying round to my Disco, i actually disconnected the battery lead before i fitted the isolator, the stories kinda worried me LOL
I fitted a manual battery isolator, no noticable current drop at all (it still performs like it did without the isolator). Ideally i would like a solenoid type that i can hit a switch in-cab to power up, but this will come when the dual battery does.
Will
I would fit an isolator for a couple of reasons. First is to stop the (fairly remote) possibility of some ****ed dickhead wrecking your car, and also if it has a wireless remote, to stop any interferance starting the winch when spooled up. There would be a chance of this happening if you were near another vehicle using its winch with a remote.
When I put mine in I will definately be doing this - it is a quick and easy install.
