I have a set of QT 3 degree double cranked trailing arms to put on my 1980 RRC which will have a 2 inch lift. I have put them on to the axle housing end and due to the different width at the axle mount end it looks like it's going to restrict down travel. It looks like I am going to have to get the angle grinder out and modify the mounts. The original mounts have a semi-circular recess to allow for the original tubular arms, but the QT arms are a bit wider and don't fit into the recess and wouldn't allow much travel at the axle end of the arm and put stress onto the chassis end of the arm.
Has anyone fitted these before ?
Can I grind away enough of the original mounts to make them work and still retain the strength of the mounts ?
Series 2 LWB - Gone
Series 3 LWB - Gone
Series 1 LWB - Gone
81 RR 2 door - Gone
95 Disco v8 - The Next Victim
This is a common problem when fitting modified rear arms to both RRC and defender rear ends.Just requires that you remove the arms at the diff housing ends, and remove some of the metal with a grinder or similar,I have removed the metal up to the semi circular portion,all the way across.You will end up with more flex than you will need.
Wayne
VK2VRC
LowRange 116.76:1
yes but im sure there are other brands of HD trailing arms that dont need grinding....
Yes I am sure that there are.Mine are a different brand and I could have left it without removing any material,and it still would have worked.But by removing the excess material,it allows a lot more movement of the arm,and in turn increases the available flex.
It is a matter of the diameter of the arm being increased over the piddly standard LandRover size.
Wayne
VK2VRC
LowRange 116.76:1
G'day, is it just me or does anyone else think Land Rover put those brackets on upside down in the first place and never got around to correcting it? Cheers, Bush Ranger.
