Results 1 to 10 of 12
Thread: Cost of new Key/remote
    Apr 2012
    Coolum
    Can anyone tell me what the cost of a new Key remote would cost ...
    supplied and configured to the vehicle.
    Thanks - for any info you may have !
    Jan 2012
    Kuranda, Queensland
    D3 or 4 . Very different keys
    Was quoted $7-800 for a D3 but then we found the old one !
    DD
    Apr 2012
    Coolum
    D3 = serious price?
    really that much? I would have thought that half that would be high price.
    Oh well ?
    What about one cut to go surfing = no electrics?
    anyone?
    Feb 2010
    Mount Martha
    Quote Originally Posted by coolum View Post
    Oh well ?
    anyone?
    Those days have gone where you can tuck the key into the wetty and go for a surf.
    Cheers, Craig
    The key cut & programmed to the vehicle is between $400-$500 depending where you go.
    If you order through a dealer then it is a UK VIN order only.
    You can get a blade only cut as some locksmiths will & can do it, but are few & far between. This means removing the door cap on the passenger side to get in find remote & turn off alarm!
    Sent from my iPad using Forum Runner
    Sydney, Australia
    D3 one is waterproof to 30m.
    Apr 2012
    Coolum
    Quote Originally Posted by CaverD3 View Post
    Sorry, but is this a fact, or fantasy, not that it would fit in the wetsuit anyway.
    I know its multi function and I know the battery is charged when in the ignition but i cant see it going swimming.
    Thanks for all the other information - everyone
    Douglas Park, NSW
    It was promoted as such by Land Rover but I wouldn't like to put it to the test.
    Oct 2006
    NSW Riverina
    I'm laughing at this thread with experience, yesterday my 14 month old son had hold of my keys when I was taking the shopping in. I heard a splash & the keys went into the dogs water bowl. They would've been in there for about 30 sec, wiped them off & it works fine.
    Rob ;-)
    Jan 2010
    Edmonton Alberta Canada
    Key Blade LR part # CWF500011SW
    Can anyone tell me what the cost of a new Key remote would cost ... supplied and configured to the vehicle. Thanks - for any info you may have !
    In July 2011, my LR dealer ordered me per the part number above for my LR3, a factory cut to serial number, key blade only, (no key fob).
    When the cut key blade arrived from the UK, my dealer then gave me a non working old LR3 key fob into which I inserted the new cut key blade. I now have same wrapped in a plastic bag and located under the 3 so I can get access via the hidden key hole should I lock my working key fob assembly inside.
    In other words, yes, you can create a "swimming key" that can at least mechanically get you into your 3. Cost for the cut key blade shipped from the UK via Land Rover Parts was $CDN 41.77 plus taxes and included cutting in the UK.
    From date of order, it took about six weeks to actually receive the cut key blade. I then had to prove I still owned my 3 before they would turn the prepaid cut blank over to me.
    I suggest that you order the blade factory cut as if you believe the stories, the factory blank is of a harder metal than is common and hence local locksmiths often cannot properly cut the metal.
