My guess is crank sensor also.
You stated that the fuel pressure regulator had been changed and the crank sensor is down behind it on the top of the bell housing. I'd pull the plug to the crank sensor and give it a clean before putting it back on. It's not easy to get to though ...
This doesn't explain the horn's behavior though. Was it the horn that is on the firewall? This is the one for the security system (I think ...)
				-- Paul --
|  '99 Discovery Td5  5spd man with a td5inside remap | doesn't know what it is in for ...
|  '94 Discovery Tdi   5spd man | going ... GONE
