Results 1 to 10 of 17
Thread: solutions sought
    Jan 2012
    cairns
    solutions sought
    hi all thankyou for all that give their time to inform us learners .,recntly bought at auction a 02 td 6 range rover it starts and drives but the front suspension is dropped also radio wont work checked compressor seems fine no water damage have tried reset procedure i am of the thinking the ecu may have made some kind of shutoff message to the pump but am guessing all else seems fine i am in the cairns area and good help is real hard to find here would appreciate greatly any feedback [positive] that is
    THANKS HEAPS
    Jul 2008
    Cheltenham, Vic
    Are you getting an air suspension inactive fault message on the dash or is it just dropping over time and then pumping itself up when you restart?
    Aug 2010
    Sunbury, VIC
    If an airbag starts to leak on these, they will lock out that corner of the vehicle from the compressor so they won't even try to pump up until the repairs have been made and the fault code cleared. This saves the compressor from running too long and burning out, and also allows the rest of the cars airbags to operate to get you home.
    Which corners of the car are sagging, and as ariddell asked - so you have a fault message up, etc?
    The more info you can provide, the better the diagnosis .
    Oh, and congratulations on your purchase - I hope that there aren't any other issues with it.
    Cheers - Gav
    Jul 2008
    Cheltenham, Vic
    Quote Originally Posted by bacicat2000 View Post
    I don't think that's actually the case, our old L322 popped a front airbag and it didn't throw any code. Would drop on that corner and the compressor would pump up that corner again when you restarted or when level stopped at junctions - replaced the airbag pronto as I didn't want it stressing the compressor running it too much.
    Manly QLD
    Both are right.
    Fault will come up if the compressor overheats, or if the system pressure doesn't rise when the compressor is running - this sounds odd but if the split on the roll of the bag opens and allows more air to escape than the pump can supply for a couple millisecs before (the split) gets pinched closed again it will trigger this error (Pressure not increasing while pump operating). Both these will give the Air Sus Inactive message
    If the compressor can still comfortably lift and maintain height with the leak, no fault will be recorded.
    Jul 2008
    Cheltenham, Vic
    Makes sense, with that leak it was a split right on the roll which sealed to some degree when pumped up so it wouldn't have triggered a pressure not increasing fault.
    Jan 2012
    cairns
    hi agn .,thankyou for your feedback.,
    i do not have any other fault codes on the dash besides the airbag symbol.,the wagon makes no effort to pump up suspension at all and
    when started and in drive pump does not operate that is the pump under spare at rear .,noticed after checking all fuses that there is another pump mentioned have not identifie4d this as a possible cause .,have a feeling though that someone may have gone through and played with it prior to me buying and cleared codes .,yet another issue occured yesterday after we finished checking pump and fuses etc treid restarting and key wont turn and gear stick wont move had similar probs with td5 and and put ageing key next to rear window and done a super unlock ., fixed issue will try this .,.,
    thanks to all
    Jan 2012
    cairns
    another intersting thing is when entering the car there is a funny clicking or knocking sound from under consul area and i have noticed because it sleeps close to my room that this seems to happen periodicly throufgh the night
    have got battery up to 12.8 v on charge and it seems to be fine and to answer aridell question bothfront suspension bags are dropped at the same level at bottom i guess .,cheers
    Jul 2008
    Cheltenham, Vic
    Clicking under the dash will likely be one of the ventilation blend motors, on ours it was one in the drivers footwell in the centre at about ankle height that was doing it.
    If both front have dropped then i would suspect a valve block or air line fault rather than the bags themselves.
    Manly QLD
    Sherrif, if you are planning on DIY maintenance you WILL need a diagnostic tool. Land Rover (Like most manufacturers) have only adhered to the OBD2 standard with the engine ECU so cheapo generic scanners can only read/clear engine ECU faults – therefore will be hopeless for this problem.
    The question asked at the top didn’t get an answer – Does it rise up when the car is started?
    With a good diagnostic tool like Fault Mate or IIDTool you can firstly read any faults stored in the ECU.
    You can then instruct the computer to start the compressor; this will confirm whether the compressor functionality works. If not, test for voltage at the compressor (check whether it’s the compressor itself) or its not getting any voltage – then work up the line, relay, signal from the ECU, fuses (yes more than 1), however if the compressor relay / fuse problem exists the ECU usually knows about it and reports a fault.
    You can then instruct the ECU to open the inflate valve and direct air to each corner in turn. This will confirm that the values are functioning (or not), there is a Pressure side valve, Exhaust valve and then one valve/corner
    You can also see the values returned from each height sensor to confirm that the ECU is receiving data that the front is too low, you can see reservoir air pressure, pump temp ect ect. It should be possible to identify the exact problem without getting your hand dirty.
    There are several diagnostic tools on the market, some (US developed) don’t interface with the diesel transmission and some will allow fault reading/clearing but won’t be able to do function testing like I described here. But if you are going to fix things yourself, it will pay for itself very quickly and will be essential.
