I don't know the garrison kit, but the felt lined bailey channel that replaces all the rotten stuff in your defender sliding window frame is profile No. 350.360.
This is what I posted some time ago when I did my rear window.
"After getting the wrong sized bailey channel to fix my rattly window,I tracked down the wholesaler and got the code for the correct stuff. You can get it from them by calling in or by phone order /mailout. Also you can order it through any Clarke rubber store. The clarke bloke at castle hill (sydney), says he will also stock it. The code is ; 350.360 flocked bailey channel .The company; Spectrum
4/4 Appin Pl
Dunheved
NSW 2760
Ph (02)96235333
Fx(02)98331041
They also have a website ,but it's currently under repair or construction or something.
You,ll need 4 metres to get right around both sliding panes of each window you tackle. This makes for a VERY snug fit. I ripped out both the upper and lower felt from my window even though the upper stuff was not in such a bad state, and perhaps there's a case for leaving the top felt in place and only replacing the bottom piece where all the crud and wear occurs. this option might result in an easier sliding finished job, and only use half the material. BTW the 4 meters I got cost about $29.00"
Don
