Connecting the Fluid Supply to the Engine
 For maximum performance, the inlet port for the Flashlube fluid  should be between the Butterfly valve and the inlet manifold. Installing  it 50mm to 100mm away from the Butterfly should provide good mixing  with the air/fuel stream. Drill a 3.5mm hole in this location (use  grease on the drill to pick up the swarf) and insert the self taping  connector. Use a suitable thread sealant to eliminate the possibility of  a vacuum leak.
 Attach the fluid supply hose from the Flashlube reservoir to the manifold fitting and fit the supplied clamp.
