Thread: RRS wheels
    Seaford Vic
    RRS wheels
    Hi Everyone,
    Can anyone tell me which L-R wheels fit a 2006 RRS to use as off-road rims.
    Westy
    Ps I have tried to do a search but on answers found.
    Dec 2010
    Parkdale, Melbourne
    If it's a TDV6 without Brembo brakes (on the front) then anything off the D3 from 17" upwards. If it has Brembos or is a petrol V8 then it's 19's.
    Mar 2012
    Northern Rivers NSW
    Mike,
    The D3 V8 can fit LR 18" wheels. Isn't it the same for the 2006 petrol RRS?
    Ken,
    I am going to guess at it being a TDV6.
    If it is a Diesel variant & does not have Dynamic Response/Brembo brakes as this was a package deal,
    Then any of the rims fitted to a D3/RRS will fit from 17,18,19 & 20.
    If you have the DR/Brembo's then you are stuck with a minimum 19. GOE (aka Gordon) may be able to get around this with his imported 18's so best to check with him direct.
    If it is a V8 then minimum wheel is an 18.
    Again, if you have the DR/Brembo's see line above.
    Sent from my iPad using Forum Runner
    Dec 2010
    Parkdale, Melbourne
    Quote Originally Posted by Learner View Post
    Mike,
    I sit corrected, I know it has the bigger diameter front brakes than the TDV6. I've seen a few of the G4 RRS's with 18's on, however istr there's one that doesn't fit hence saying it's best to stick with the 19's. There's a full fat RR 18" rim that fits as well, it just looks rubbish.
