Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Coolants for older engines
    Narre Warren South
    Following on from a thread in 'Technical'.
    Demineralised or distilled for radiator
    A lot of coolant manufacturers do not state what corrosion pack they use in their coolant so you have to speak to their technical dept. to find out which is suitable for older engines.
    There have been problems reported using OAT type (long life) coolants in some older engines so you should be aware of what corrosion pack is used. OAT may damage solder and gaskets & sealants using silicon.
    I'm no expert but there are IAT (Inorganic Acid Technology), OAT (Organic Acid technology) & HOAT (Hybrid Organic Acid Technology) corrosion packs. It's confusing, especially when the manufacturer states 'suitable for older engines', which they mean to be maybe 10 years old not the 50+ years of some of our Land Rovers.
    IAT is the old, traditional corrosion pack used for many years.
    Nulon have just informed me that the Dr Cool is suitable for older engines and uses an IAT corrosion pack Dr Cool Concentrated Coolant- Nulon Australia
    I await replies from other suppliers.
    As already mentioned, I'm no expert but by reading what's out there I've come to the conclusion that I should be looking for an IAT based coolant for my Series Land Rovers mixed with demineralised or rain water.
    Hope this helps,
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    drifter Guest
    Appreciate the info and look forward to further discussion/consensus on this. It's something I have wondered about.
    Narre Warren South
    Valvoline don't have an IAT coolant in Australia, they have a HOAT that "can be run in some older engines" problem is whether the Landy is one of the "older engines" they refer to.
    Nulon list a 2 year shelf-life for Dr Cool. They are not saying it won't work but it's difficult for them to give a "guaranteed performance" after that date. I wonder how they would prove it's manufacture date if you had a problem after a year. I don't keep the empty bottle or the receipt (but maybe I should). I've asked whether there is a date code on the container, I await the reply.
    Awaiting a reply from Castrol still.
    Any other coolant suppliers I should try ?
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    I use the standard green tectaloy coolant available from kmart, supercheap most servos, repco, autobahn and truck stops everywhere.
    Narre Warren South
    The thing is does it use IAT, OAT, HOAT or some other corrosion pack.
    I've just emailed Tectalloy and also Shell so more info as I get responses.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    Castrol Anti-Freeze Anti-Boil is HAT (Hybrid Additive Technology) . I mentioned to them that I'd been using this in my old vehicles and the reply was that "if I had been operating trouble free then I should continue to use the same product".
    I might send another enquiry from another email address asking for their recommendation for a 50+ year old vehicle.
    Shell replied but recommended an OAT or a long life (no details of the corrosion pack) so I've gone back to them for further information because I'm not keen on using OAT and specifically asked for IAT.
    Just been browsing the net again :-
    Tectalloy Extra Cool needs to be replaced every year.
    Tectalloy Extra Cool Gold lists only a Km replacement (60,000 if tap water used and 100,000 if demineralised water used). It's a second generation OAT.
    As a 'rule of thumb' it seems that if the coolant needs replacing every 2 years or less then it's probably IAT or maybe HAT.
    Ethylene Glycol raises the boiling point and lowers the freezing point of the coolant but may not be needed if it's not originally specified. Apparently it helps deal with local hot spots within the engine where the temperature may get above 100C. A corrosion inhibitor added to distilled/demineralised/soft water may be OK for Series Land Rovers.
    The more I look into this the more confusing it gets, especially when the 'Technical Support' for the companies don't give straightforward answers.
    It's going to end up like a discussion on oils where everyone has their own preference because of what they believe.....
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    Interesting reply from Shell who state that their OAT & HAT coolants are OK for older vehicles
    "Yes, Shell do sell coolants suitable for older vehicles.
    We assume that IAT is inorganic additive technology, more commonly known as CAT - conventional additive technology.
    Our product, HD Coolant N Pre-Diluted, is such a product.
    I have attached a TDS for your information.
    However, our HAT (hybrid additive technology) and OAT (organic additive technology) products are also suitable for older vehicles.
    In the distant past, incorrectly formulated HAT and OAT products could sometimes cause seal and solder issues.
    Our Shell products, LongLife OAT (OAT), MultiVehicle Antifreeze Coolant (HAT) and HD Premium N Antifreeze Coolant (HAT) have never shown any issues with solder and seals.
    Hope this helps."
    It seems that the OAT, HOAT (HAT) problems were in the past and most coolants should now be compatible.
    Being a creature of habit it looks like I'll be staying with the Castrol Anti-Freeze Anti-Boil and put up with the 2 year replacement. Autobarn have 20% off for RACV members this month so I'd better stock up.
    Hope this helps.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    Now I'm confused .....
    Tectalloy replied
    " You are correct an in-organic / conventional style coolant is much better suited to older vehicles.
    We have three products in the Tectaloy range that meet this criteria.
    Tectaloy 60 Plus is a pre-mixed ready to use conventional style coolant. Formulated for general purpose use and is designed to meet the demands of normal passenger vehicles under light to normal driving conditions.
    Tectaloy 90 Plus is a pre-mixed, 33% anti-freeze anti-boil ready to use conventional style. Suitable for passenger vehicles requiring anti-freeze anti-boil protection, and those vehicles put under increased loads e.g. towing
    Tectaloy Anti-Freeze Anti-Boil is a conventional style concentrate, that can be blended between 25% - 50%. Suitable for passenger vehicles requiring anti-freeze anti-boil protection, and those vehicles put under increased loads e.g. towing "
    Different answers from different companies.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Meredith vic
    coolant
    You dont need antifreeze here in Aus unless you are going to park your car in alpine areas for more than 1 night. Antifreeze, ethylene glycol, is sugar based, and will turn corrosive in the wrong concentrate. It also crystalizes over time, depositing an insulating layer iside your radiator. A 5% loss of flow caused by this layer can cause your cooling efficency by around 20%!
    All you need is a good quality corrosion inhibitor. We use the Tectalloy OAT coolant at work and have never had a problem.
    Narre Warren South
    From my limited research the ethylene glycol based coolant is recomended for some engines where they have local hotspots as it boils at a much higher temperature. Early Series Land Rovers wouldn't have had ethylene glycol recommended originally.
    If you run it at the wrong mixture you are likely to cause corroson problems because the anti-corrosion pack will only give protection if the coolant mixture is used at the correct ratio. My Defender has used it for over 12 years with no problems.
    Using ethylene glycol based coolants at the correct mixture is only likeley to cause a very small extra amount of lightening of your wallet.
    Some coolant manufacturers are not recommending OAT type anti-corrosion additives in older vehicles, some are. It seems there were some serious problems with OAT damaging gaskets, sealants & solder in older vehicles. Some manufacturers are listing 'second generation OAT' which maybe highlights that there was a problem but they have now resolved it.
    Tectalloy's technical dept. stated that an in-organic (traditional) anti-corrosion pack is better suited to older vehicles.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
