Results 1 to 10 of 21
Thread: van heaters
    May 2003
    On The Road
    van heaters
    anybody run one of these?
    any thoughts?
    Webasto - Heating Systems
    Central Coast NSW
    Haven't got one but these are the go.
    Pretty exxxxy though.
    May 2003
    On The Road
    any $$ ideas?
    Douglas Park, NSW
    There was an ad with one of the 4WD Action newsletters recently with some super duper special on these.
    Link here with prices:
    Online Store | Dometic Australia
    Nov 2007
    On the road.
    i heard in the $2000 range, not cheap but effective.
    Jul 2009
    Hobart
    Hi,
    I have one in a slide-on camper (Innovan) on the back of my D130 Ute.
    Very happy with the diesel version - more heat than I need in -5 C out side.
    Economical on fuel, but can be a bit heavy on battery using the glow plug if it is cycling on and off. Best to keep it running or turn it off.
    Consider the gas version if you are in a warmer climate than Tasmania. Some advantages are no pump, less Amps to start etc, but you have the hassle of nearly empty gas bottles at the start of a trip some times.
    Not sure if you need a gas fitter to sign the install for compliance with any regs etc - don't need that for diesel.
    Happy to answer any particular questions - PM me in case I miss the post.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    here i was thinking that is why the supreme being put rocks near fires...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    On The Road
    The Keeper Of The Keys has forbidden open fires in the van,,
    pricing from a brizzy distributer,
    1300 for the small one,,
    and another 1K to install it,,,
    I can see the 1300,, but the install has to be by NASA techs,,
    Jul 2009
    Hobart
    Hi,
    I'm no NASA tech, it is not all that difficult physically, just join bits together.
    It does take a little deciphering the variations in the instructions, but that just means there is more than one way to do it.
    If you can drill a hole, cut a rubber/plastic tube, put in a screw, tighten a nut with a spanner, cut and solder a wire, honestly, you can do it.
    I've done an incar preheater version install, I cant see it being much harder with the possible exception of needing to ventilate it.
