101 Ignition Switch
I had to take the 101 in for its annual LPG certification and as usual on cold mornings it would not start right away - even with a squirt of Aerostart. So the engine had a bit of cranking on the starter - occasional kick but no go.
Now my system needs a little rest after it has been cranking a bit but is OK after a minute or so. This morning as I was in a rush I got the hand crank out and she fired and ran first go. Off to the mechanics for the inspection - no issues $45 later time to go.
Ignition on but no starter so out with the crank handle and start first go. Arrive home and the starter still does not work. Now I have not pulled it apart as yet but I suspect the ignition/starter switch. It does provide power to the ignition but when it has been cranking I suspect the switch gets hot and goes open circuit and has finally died.
I have had a look on Craddocks and Paddocks sites for 101 ignition switches but cannot find any listed =- so does anyone have an idea where I might be able to get a new switch if I need one - as I said I haven't started looking for the fault as yet (I would like it to be the starter solenoid as it is easier to replace than pulling the dash apart) but I suspect an ignition switch issue.
