Results 1 to 10 of 19
Thread: advice on bridle straps
    Mar 2010
    victoria
    Hi all,
    I'm looking at getting a bridle strap and I'm seeking advice on which is the best type, particularly advantages/disadvantages of stretch versus non-stretch.
    Is stretch better for snatch recoveries? And is non-stretch better for winching?
    Can they be used for both styles of recovery?
    Wayne
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    me personally
    i used a non stretch unit
    i eventually went for a 2 leg galv wire rope unit as it ensured i got a straighter pull.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    buddha D2 Guest
    Non stretch.....that's what the snatchum's for.........I use a dyneema rope bridle which I got from ARB in Ballarat......came with 2 x rated shackles but you have to have 2 x rated recovery points too
    Warragul, Victoria
    Non stretch.
    May 2012
    Wannanup WA
    4.70 MB
    I find that a two legged chain sling works, similar to the wire rope sling but easier to stow and carry. They come with a single "eye" with hooks on the ends of the legs.
    Moruya Heads/Sth. Coast, NSW
    Personal choice, as long as it is Non-Stretch, but have it (bridle) as long as possible to keep the angle (top of triangle formed) to as far below 90 degrees as possible, 30 to 45 degrees or less ideal, Regards Frank.
    Mar 2010
    victoria
    Quote Originally Posted by Tank View Post
    Looks like the consensus is non-stretch - thanks everyone.
    So is this just marketing or is there actually engineering science behind it?
    Recovery Bridle - 4x4 Accessories - Recovery Gear - 4wd Recovery Gear | 4wd Accessories | 4wd Equipment and Camping Gear Australia | Axe and Shovel Holder | Combo Shovel | Synthetic Winch Rope | Camping Lights| Autofridge Eutectic Refrigerators|Pillo
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    I thought that a tree protector strap is also equally suitable as a bridle. The recovery kit I bought promoted the tree protector as dual purpose. cheers MLD
    Quote Originally Posted by MLD View Post
    Might be OK for winching but most are too low a rating for snatching - now I use them for my truck but I use two of the same length and rating when snatching.
    Quote Originally Posted by BreakingBad View Post
    Not all recoveries are snatch strap recoveries, using a stretch strap as a bridle on a winch recovery could be dangerous esp. with a tifor winch.
    In a winch recovery with a snatch bridle strap the stretch in that strap will be taken up before the vehicle starts to move, then when it moves it could leap forward catching the winch operator unawares. This could cause undue strain on the winch cable and the jerking could cause the cable or shackle to part. Also if using a Tirfor you are standing next to the winch and a sudden movement of the vehicle could cause a dangerous situation, this is why stretch type straps are banned in the rigging industry, Regards Frank.
