                                                27th July 2012, 12:10 PM
			130 Defender directional stability
					Well I finally got the Defender mobile, well for about 2 Kms up the road  before one of the treads lifted on a rear tyre, limped home thud, thud , thud ………………………at 25Km/h.
 Well, four new/second hand, actually five, tyres later it’s back on the road. At least these ones are balanced and a lot smoother than the old Firestone tyres. Managed to find 5 identical Bridgestone AT’s over 2 different dealers which was a bit of luck. All the same fitted and balanced, good 6-8 mm of tread, for $370. Could be worse.
 On my test run up the highway I notice that when accelerating the vehicle pulls to the left and decelerating pulls to the right. Not a lot but noticeable. So I guess this means either a/. the 300 Tdi is so powerful  the torque of the engine is pulling the Defender to one side or b/. the rubber mounts on the rear suspension arms where they join the chassis have had it. I’m thinking the latter.
 Any thoughts.
 Deano
                                                27th July 2012, 12:54 PM
					I had the same problem on my 300tdi disco, definately the tourque produced
                                                27th July 2012, 02:44 PM
					Check the front radius arm bushes too - particularly the ones at the diff end of the arms.
 Steve
                                                27th July 2012, 05:38 PM
                                                #4
					Deano, steering under throttle is more than likely the rear trailing arm bushes, as you have said.
 Even a 300Tdi will cause this phenomena...
 JC
                                                28th July 2012, 12:08 AM
                                                #5
					Definitely the bushes as my 130 was doing the same. Turns out someone had dodgied up some bushes from another vehicle on the rear arms where they connect to the chassis and was doing exactly the same as yours
                                                28th July 2012, 09:33 AM
                                                #6
					Take the front prop off and check to see if the slip joint has seized.
 Tim
                                                1st August 2012, 10:14 AM
                                                #7
