The 12 volt shop is advertising a 19" Teac combo TV which has a power consumption of 60 watts. This is pretty much the same as a car headlight. In round figures this is 5 Amps. So how long the TV goes for depends on the size of your battery and the length/dia of your 12 volt cable (voltage drop / power loss issues). Might be more efficient to run a small inverter if the distance between the battery and the TV is an issue. Also as you double the supply voltage in a given power cable you halve the current and QUARTER your power losses, but living in 12 volt land you probably know this.
From a theoretical viewpoint an N70 100 AH battery will last 20 hours but in practice probably half that taking voltage drop, TV low voltage cut out and not totally flattening the battery into consideration.
Deano![]()
