Results 1 to 10 of 14
Thread: D4 Windscreens and service
    SteveL Guest
    Hello Aulro people. Our D4 is our first LandRover and its very interesting. People we meet on our trip ask questions which make us think that we have joined some sort of masochistic club!
    We have fitted 18" rims with BFG AT's, Gordons rock sliders and a snorkel. Otherwise, its standard.
    We came up to Darwin via Birdsville, Mt Isa, Borolloola, Roper Bar etc, bloody awful roads and managed to break both windscreens, front and back.
    On one ten hour day, we averaged only 49 Klm per hour! We won't do that again, its just to big a day. We usually try to pull up by 4.
    I'm leaving the front screen until we get home but the rear one was replaced here in Darwin. Ouch!
    I'll be trying to get windscreen O'Brien to fit an OE item. Agsain as a result of something I read in this forum.
    The car itself has handled these conditions beautifully, it is absolutely unreal to travel in, we love it. We have towed an Ultimate all the way and have had no problems at all.
    We're due for a sevice shortly, cant get it done in Darwin until next week. No good to us. I have brought oil and filters with me and have been thinking about doing itmysel but as usual, this forum tells me that a garage in Broome will be able to do the job. I'll be ringing them on Monday to book in as I can imaging how busy yhat place is and I don't want to stay there any lomger than I have to. Way too many people.
    Steve L.
    mandurah
    Hi Steve,
    Where did the damage come from. Other vehicles or a bounce off the trailer ?
    D4 2.7litre
    May 2010
    Northern Beaches, Sydney
    If you haven't already done so, get windscreen replacement cover. Particularly if you do a lot of country driving.
    May 2011
    Bugger, I thought the shape of the Ultimate would help protect me from smashing my own back window.
    It would seem it isn't so.
    Quote Originally Posted by SteveL View Post
    ........ bloody awful roads and managed to break both windscreens, front and back.
    ............. We have towed an Ultimate all the way and have had no problems at all.
    Steve L.
    May 2012
    Quote Originally Posted by Weird Al View Post
    Steve, I cracked a windscreen (200mm) after a stone flicked up from a passing car. D4 is only 10 weeks old and I was towing the van also.
    After stressing about it all weekend, I was pleased that my insurer happily accepted replacement with an OEM windscreen, fitted by Windscreens O'brien.
    Rgds, John
    Mar 2012
    Gabbadah WA
    Years ago people used to put a comercialy made mesh protector in front of the windscreen when going bush , dont know if they are still available but i know they saved a lot of heartake .
    JamesH Guest
    When you're towing a camper trailer or van a good trick is to cover your rear window in that plastic cardboard sheet stuff. I ve seen too many cars in roadhouses on trips with cardboard inserts where the window used to be, they learned too late.
    Quote Originally Posted by Fatso View Post
    Years ago your windscreen also shattered into a million pieces or before that it was dangerous shards...
    Hence the mesh screens...
    Mar 2012
    Gabbadah WA
    Yep they sure did !!! , dont much matter how they break the end result is there broken , a bit of prevention is better than a whole lot of cure.
    15 smashed windscreens over 25 years and goodness knows how many kms..
    With 12 of those broken in the city(s) - errant stone of a car/truck...
    Of the 3 broken out of the city (the only time anyone would run a mesh shield) the drag (extra fuel used), impairment of vision etc is hardly worth it.
    A modern, laminated screen can take a bloody decent hit before chipping / cracking.
    I've had a piece of Iron Ore hit the windscreen at an estimated 160km/h from a passing Ore transport and we suffered a single "bullet" crack.
    Outside the drivers viewing area, so a simple stone repair sorted it... $50.00 done!
    And you dont need to butcher a vehicle bolting mounts etc
    Sometimes that Ounce of Prevention can be more expensive then the cure
