5th August 2012, 07:36 AM
Wiring out to roof rack
Looking for advice on getting power out the back of my defender to my roof rack for 4 small LED flood lights.
Each light is 10w and I will have them separated into two sides so 20w per side.
for wiring I was going bring it in through the rear side panel above the gutter through a gland. I am thinking now if I ever remove the roof rack it could be an issue so my alternative is fitting a flush mounted socket, looking at the 7 pin small round one, and have a plug on the light end to connect in, these are the ones used on trailers I am talking about.
I think this will be OK.
But I want to be able to make it expandable in the future so if I was to fit an LED lightbar up the front at some point would the small sockets be able to handle the power?
Is there an alternative to using this type of socket and connection?
I am sure it has been done many times before but not had much luck with search.
thanks
Pat
5th August 2012, 05:04 PM
One of the things that motivated me to put a snorkel on the Rangie was to use it as a conduit for the wiring to my rooftop bull lights, straight from a relay near the battery and up to the roof. Anderson plugs of appropriate size for the application are probably a better choice than a trailer plug.
6th August 2012, 09:57 AM
I wouldn't bother with trailer connectors.
"Bulgin Buccaneer" are the ones to use - Standard Buccaneer. IP68 Waterproof Electrical Connectors by Bulgin Components
- IP68 rating tested at 1.054kg/sq cm (15lb/sq in) 10m depth for 2 weeks and 9.84kg/sq cm (140lb/sq in) 100m depth for 12 hours
- Water and dust proof to IP68 when mated
- 2, 3, 4, 6, 7, 9, 12 and 25 pole
- 12A, 277V ac/dc 2 pole screw terminal, 3 pole screw terminal and crimp contacts
- 10A, 277V ac/dc 4 pole screw terminal
- 5A, 277V ac/dc 6 and 7 pole screw terminal
- 5A, 150V ac/dc 9 pole crimp contacts
- 5A, 50V ac/dc 12 pole crimp and solder contacts
- 1A, 50V ac/dc 25 pole crimp and solder contacts
- BNC versions 50Ω and 75Ω
- Plug or socket connection in each body style
- Compact design
- Diameter over coupling ring 38mm
- Sealing caps available to maintain IP68 rating of unmated connectors
- 7 body styles - flex cable, in-line flex cable, panel mount (front), panel mount (rear), PCB mount, bulkhead and flange mount
They're available from RS - Buy Circular & other General Purpose parts | RS Components
I've had Bulgin Buccaneer 2-Way Connectors on my 110, used for the Rear Worklamps and Power Sockets, since I bought it new in 1989 -
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
