Results 1 to 10 of 25
Thread: Hard-wired USB ports for charging
    All,
    Am thinking of ditching the original cig lighter abomination of cables and adaptors for a multi (2 min (or more if available)) USB ports as below.
    This would enable direct connection of chargers via USB cables and powering of the tablet/GPS and Nanocom.
    There's no wiring details on the ebay page and messaging them they say instructions are included, but won't detail them. Don't want to get stuck with an issue and also there may be other cheaper options to achieve the same end result without the big plate.
    Has anyone done this before or have extra details for the wiring into the ports of which connection is which. From what I've read there's a 12 & 5v and gnd thats all thats necessary for power.
    Dalby
    Have you got a link for that part?
    I am surprised there aren't more USB panels around as surely the no. 1 thing to plug into a cigarette socket these days is a USB converter.
    I've been looking for something like this for a while but never found one. Closest things are the near flush USB inserts for ciggy sockets.
    Dalby
    Quote Originally Posted by clubagreenie
    It should be just 12v positive and negative.
    It would reduce the output to 5v internally.
    Mar 2009
    Port Stephens N.S.W
    I looked at these recently to setup power for my new iPad ... but max' output is 1A and the iPad needs 2.1A
    Would be OK for all the other USB powered stuf, and a great idea for reducing dashboard clutter.
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    The ratings the reason for looking at doing it differently, from what I can find on other places the ports PCB contains a reverse polarity/current liniting/self restting fuse type circuit. A few people seem to refute the usefulness of this and cut it out and put a 2A fuse in line, after tapping off say the lighter circuit.
    There's a couple of examples on indestructables but their finishing leaves a lot to be desired.
    East-South-East Girt-By-Sea
    1.20 MB
    Was sure that I recently saw an accessory panel for the SIIa Land Rover which had 2 USB sockets, but can not find the link at present (sitting behind a shopping restricted firewall).
    What I do know is that the USB ports in my D4 don't provide power to re-charge a phone or GPS (or at least they don't with the cables that I have).
    Addit: This is the item I saw previously: http://www.ebay.com/itm/Land-Rover-S...item4ab51a1ea5
    They also have a panel for the SIII.
    Jul 2009
    Hobart
    Hi,
    Would some thing like this suit you?
    Details here
    St Helena,Melbourne
    4.28 MB
    I'm sure you could get the components from jaycar cheap enough and then make the output suit your equipment.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Illawarra
    I have one of these from Jaycar. It does a 1A and 2.1A outlets
    3.1A Dual USB Car Adaptor - Jaycar Electronics
    At this stage it is just sitting in the cig lighter socket. The longer term plan was to pull it apart and permanently mount it in the dash.
    Given the interest I will do that tonight and post pics.
