Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: Soldering irons
    Dalby
    Soldering irons
    Hi all,
    What soldering irons are people using for auto electrics?
    I have a Portasol Super Pro gas soldering iron from Jaycar. About 10 years old and no longer works properly. Had it for work originally but has only had hobby use the last 8 years or so.
    I've been looking for a Weller electric soldering iron but can't find anyone who sells the good quality ones.
    Was thinking the W60PD3 with a chisel tip if you can get it in Oz.
    I want something quality not Bunnings junk. Even Haymans and Ideal Electrical only sold same type as Bunnings.
    So what do you use and who sells quality soldering irons?
    http://www.apexhandtools.com/brands/...%20Iron%20Kits
    Apr 2010
    South East Queensland near the sea...
    Until recently I worked in the electrical/mechanical fit out of power boats. I used the Weller Portasol Super Pro and can't recommend it highly enough. I went through a couple in about 4 years of heavy daily use. They are not cheap at around $140 but for ease of use and portability you can't beat them.
    I've had great success with the following:
    2000 VersaTip
    For more electronic work, I use a Re-Work station.
    I have 3 Irons, 15w, 25w & 40w (all from Jaycar). The higher two are the Duratech orange units, the 15w is a goot (that's not listed any more, tey have a 46w for $80-). Have lasted years now, all tips are available from Jaycar and I keep a few spares in different shapes etc. All up was <$100-, at current pricing as a comparison, for a 25w $13-95 & 40w $18-95.
    The Goot station is good value at $299-.
    May 2009
    If you're just soldering wires grab an 80w, that way you can un-plug it and still use it to get to those awkward places.
    Dalby
    Quote Originally Posted by iPom
    This one?
    http://www.jaycar.com.au/productView.asp?ID=TS1318
    That is what I have now. Didn't realise Weller made them in that case.
    The Dremel one Tombie mentioned sounds essentially the same.
    I agree you get what you pay for usually. However a good quality electric should outlast a good quality gas unit by a big margin.
    I'm sure I'll get another gas one sometime though as they are so handy. Just expensive.
    Dalby
    Quote Originally Posted by clubagreenie
    I've never seen Goot stuff before but Jaycar talks them up on their website. Worth a look but a bit low powered for what I was after.
    Dalby
    Quote Originally Posted by Tombie
    2000 VersaTip
    Google says half the price of the Portasol but I've never seen them in a shop.
    Where did you buy yours?
    My 25w Goot is as useful as the 40w Jaycar unit, difference is the tip size and longevity of the retained heat.
    Apr 2010
    Quote Originally Posted by Utemad View Post
    This one?
    <Portasol> Pro Piezo Gas Soldering Tool Kit - Jaycar Electronics
    No, mine came in a different case. Mine is rated up to 125W and has a 4.8mm tip as well as a 2.4 and the rope cutter, heat shield, blow tip etc.
    I agree that a 240V will probably last longer, the ignition generally fails on the gas irons. It still works although I have to light the flame with a ciggie lighter. In general with any iron it is the tips that fail first. Keeping them tinned and clean with a damp cloth or sponge is the way.
    I reckon you just can't beat the portability of gas irons. If I had lots of bench work to solder I would use a 240V as Tombie as suggested.
