Results 1 to 10 of 13
Thread: Vitese 4.2 V8 how different to 3.5?
    East-South-East Girt-By-Sea
    1.20 MB
    Have been talking to a mate today about a 4.2 litre V8 fitted to a RRc by Vitese Developments and it struck me that I know very little about them.
    Are they a development of the 3.5 V8 or the 3.9 V8 and how do they achieve the capacity increase?
    Anything to look out for with one of them?
    Thanks for any info people may have.
    Diana
    Diana, I'm sure I have either an article on them or an advert from the '80s. I'll have a look over the next couple of days.
    Do remind me so I don't forget.
    Kingston, Tassie, OZ.
    hi diana, iirc they used 3.5 (early on) , which had a stroke increase, then i think later based on 3.9 with a stroker crank. they used omega 9.5:1 pistons, and early motec injection. they are a very well thought out and built engine.
    jc
    Eastern Suburbs, VIC
    my old man has a vitesse developements 4.2 in his rangie, very balanced and rev happy engine. used to run an early motec system, but now runs megasquirt ecu.
    as JC said; well sorted engine.
    1986 Range Rover Hiline
    2004 D2 TD5
    Diana
    yes, if it needs a rebuild/ bore, omega pistons are no longer available
    last one we did, (a 3.9) original pistons were perfect condition so resleeved block and reused them, had to find compatible rings which meant machining ring grooves slightly. worked out well and years later still going well bore was std 3.5 so crank/ rods were the capacity increase.
    jc
    1.20 MB
    OK makes sense stroked 3.5.
    If the pistons are no longer available, could you re-sleeve to 3.9 bore and use 3.9 or other compatible pistons?
    What does a stroked 3.9 come out to?
    the stroke increase, high compression ratio and motec 'map' gave these engines some impressive torque, yet they still revved well
    careful of gudgeon heights if using the original rods, may have issues finding the right pistons, but i have never delved that far. TRS were getting out to 5 litre by stroking and a slightly bigger bore/ liner, and forged pistons, Scat rods etc.
    jc
    St Helena,Melbourne
    4.28 MB
    About 4.7ltr i believe .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Agreed, mine was about 288 cu in.
    JC
    1.20 MB
    Good news, my friend bought the engine and Motec and we removed it from the donor vehicle yesterday.
    Would it be O.K to use the standard 3.5 flywheel and pressure plate or should he use an upgraded pressure and friction plate?
