Thread: Whistling sound after engine start
    Feb 2010
    Stellenbosch, Republic of the Western Cape, RSA
    Question Whistling sound after engine start
    Gents,
    Just started noticing a whistling sound straight after the engine cranks over, should I be worried?
    Aug 2012
    kootingal NSW
    What have you looked at does the whistling change with engine revs ? Have you tried running the engine without the drive belt?
    Feb 2010
    Quote Originally Posted by 30t of coolness View Post
    I haven't looked at anything yet, looking for suggestions.
    The whistling noise is quick and only lasts for 1 or 2s. It does not re-appear under revs/drive.
    It's also more high-pitched than the normal turbo whistle.
    Aug 2012
    kootingal NSW
    Geez bloody hard to say without hearing starter not disengaging straight away maybe ???
    Kremlin Guest
    Whistle after start
    Check the bolts on the exhaust manifold, I have just had the same noise fixed, it ended up being 3 snapped bolts. Its not an easy fix but it needed to be done.
    Feb 2010
    Quote Originally Posted by Kremlin View Post
    Crapsticks! Do you think the exhaust manifold is warped as well?
    Jul 2011
    Scotland
    Naks, I had something similar and posted on my fault finding route here:
    http://www.aulro.com/afvb/90-110-130...a-turbo-2.html
    Brian.
    Feb 2010
    Quote Originally Posted by Lorryman100 View Post
    Naks, I had something similar and posted on my fault finding route here: Puma Turbo
    Brian.
    Thanks Brian, so it could very well be the exhaust manifold then.
    I am loathe to have this done by the stealers, their incompetence scares me sleepless. Who know what else they will break in the process...
    The truck is only under warranty until Feb 2013, maybe I should wait until then and then have my trusty indie do the fix with the copper gasket and a hybrid turbo...
    Mar 2010
    victoria
    Quote Originally Posted by Naks View Post
    I'd get this issue fixed under warranty.
    Then shortly before warranty runs out, take it to your trusty independent specialist and get them to list everything that needs fixing under warranty. Then go back to the dealer and get them to fix it. If one of those things then breaks prematurely out of warranty you should have grounds to make a claim. ie: Either it wasn't fixed properly (or not at all), or the parts used were faulty. New parts and workmanship should have a separate warranty.
    Feb 2010
    Thanks, good advice!
    Took the landy in for the oil change this morning and the indie mech listened to the engine starting.
    He seems to think that it's just one of belts being wet and slipping on startup.
    We did drive through a hectic rain + hail storm last Saturday and I only started hearing the next day.
