 Originally Posted by
MacFamily
  Thanks for the recommendation... I work in the pneumatics industry and can provide what you need at a realistic price. The attached thread generated just one sale so I'd pretty much given up on it.  The standard Defender axle breathers are OK, you don't really need to put a silencer (filter) at the end but every kit includes them. The only thing I don't supply is a fancy bracket to mount the parts. Be careful with the standard Defender banjo fitting on the axles, they are zinc passivated steel (or were on the 300Tdi) and mine corroded internally & blocked up. I now have some nice nickel plated brass fittings from work.  If you want to add gearbox/transfer box breathers then you need to let me know what/where/how you are connecting the breather. Most pneumatic fittings are BSP (British Standard Pipe) threads.  You can email me on colin.radley@metalwork.com.au   Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
