Results 1 to 10 of 30
Thread: Keeping plastic trim alive
    Feb 2010
    Dont know if I'm supposed to plug products here but recently bought a plastic trim rejuvenator and it works a treat so I thought I'd pass on the info.
    I noticed the trim between windscreen & bonnet was looking faded and had a chalky appearance. Went down to local auto parts store and as I usually use either McGuiars or AutoGlym products, decided to see what they had. Found an AutoGlym product called Bumper trim gel. It cleans the surface and applies a film of water resistant barrier. It also appears to repel dust. It has been on for 2 weeks now and still looks great. Trim in front of windscreen looks like new as do the wheel arch trim plus any other plastic trim. Apparently it won't affect paint. It's got the Queens seal of approval too! Makes the car look new again. Much better than amour-all.
    Cheers Neil.
    Jul 2012
    Frankston
    I find silicon spray also does a great job of reviving the plastic trim
    Julian
    Feb 2010
    Mount Martha
    I have been told by several people never to use silicone based products, internally or externally, hence I don't.
    Re: The trim at the bottom of the windscreen that Neil was talking about - I have used Meguiars external trim detailer and it works well.......not excellent, but well. I have also used Autoglym Instant Tyre Dressing.....DO NOT USE THIS ON THE TRIM BELOW THE WINDSCREEN. Great on tyres and trim along the side of the car below the doors, however it reacts with the windscreen washer fluid and causes it to go grey and patchy.
    Sounds like the stuff Neil is using is good. I'll give that a go.
    Cheers, Craig
    If you ever bend a vehicle with silicone used on it the crash shop will:
    (a) Hate you
    (b) Struggle to get the metal sorted to Repair and respray.
    Try this: Walk into a crash shop holding a can of silicone spray - You will be crash tackled and kicked out!!!!
    Use a proper interior / exterior, polish / rejuvenator / spray
    Jul 2012
    Bendigo
    sounds like the bumper trim gel stuff might do nicely on the wheel arch moulding things too? I was going to fine wet and dry sand the coarse texture down till it was more consistent with the areas that arent worn , then apply a vinyl/plastic dye (spray). Though I still might need to as mine are faded a bit in areas and just dressing them with something might not do the job for rejuvinating the colour enough in the bad spots
    Jul 2012
    Toogoom, QLD
    thanks for the info, the trim below windscreen and the wheel arches on my 07 D3 are looking faded so would be nice to have them like new again.
    What auto spares carry that stuff? AutoGlym product called Bumper trim gel
    Supercheap? Repco?
    Jul 2012
    Frankston
    (a) Hate you
    message received Tombie
    Looks like i will be going to Autobarn!
    Julian
    A $2 spray can of tyre shine from a $2 shop works great - spray on and wipe off.
    Jul 2012
    Toogoom, QLD
    ordered some autoglyn bumber trim gel from a mob down south called "liquid diamond car care products".
    $26 with courier delivery. Will see how it goes
    Feb 2010
    Mount Martha
    Used the Autoglym gel on my black bits today.
    Come up awesome. Might use it on my wife's as well
    Cheers, Craig
