Results 1 to 10 of 15
Thread: Obtaining new U-Bolts - 101FC
    It was my intention to replace the four suspension U-bolts on the back axle and the 8 individual front axle retaining bolts before getting my 101 back on the road. Since I'm close to ordering some steering parts (replacing all ball joints) I figured I may as well get these suspension parts while I'm at it. Seems as though the 101 specific part is unavailable from the usual suppliers so I need to look elsewhere.
    A quick measure reveals them to be approximately (3.125" x 180mm). This appears close to the Dana 60 axle which I believe its copied from in which case I just need to track down some from the US.
    Another issue is according to the manual the nuts are M12 meaning the bolt diameter should be 12mm (although I only measure the bolt width to be bang on 11mm which means I possibly stretched the old ones on re-fitting???). A quick browse reveals that most dana 60 u-bolts are 5/8" (15.875mm) in diameter meaning I will have to drill out the top spring plates. I haven't looked close enough to see if this could introduce structural issues by removing 2mm of metal near the edge of the spring plate, I doubt it but I should probably look into it further.
    Before I do the above I thought I would see if anyone has had any luck obtaining quality u-bolts locally, preferably in a 12mm or 1/2" size??
    I'm making an assumption that I can get the front bolts from a speciality fastener supplier as they are just HT 8.8 12mm bolts.
    edit* I've found a Dodge Dakota uses 3.125" width bolts 1/2" in size! Now just got to get the right length.
    101 Club ????
    Nov 2007
    Gold coast
    Quote Originally Posted by stuee View Post
    What's the parts numbers?
    101 Club ????
    Dont list them as a part in the magazine any more. Going by some old forum posts I gather they used to though.
    Quote Originally Posted by juddy View Post
    U-Bolts are 624130.
    Nov 2007
    Gold coast
    I will have a look in the morning...
    Just went out to confirm my measurements and used a ruler this time for length and its actually closer to 165mm on the inside of the u-bolt which is where I believe the measurement is meant to be taken from, not the outside of the u-bolt like I did before.
    This is very close to 6.5" and pretty much an identical u-bolt to the dodge dakota.
    Dorman Products RB35621
    Auto Part Number RB35621 From Dorman Products | StreetPerformance.com
    1997-2001 Dodge Dakota Axle U Bolt - Dorman, 6.5 in., OE replacement, 3.13 in. - JCWhitney
    Parts Bin - Auto Parts and Accessories Catalog - rb35621
    Edit* One of the above wanted to charge me $81 USD to ship 4 u-bolts from the US. Will keep looking for another supplier.
    Can get a generic u-bolt the same dimensions through JEGS or Summits racing. May wait till I order my wiring loom as they still want upwards of $55USD for shipping
    Skyjacker 12X318X612
    Skyjacker Suspensions 12X318X612 - Skyjacker U-Bolt Kits - Overview - SummitRacing.com
    Narrogin WA
    Have you tried Westralia Springworks in Welshpool?
    Cheers Charlie
    Quote Originally Posted by chazza View Post
    Cheers Charlie
    Hadn't heard of them before. Just checked out their website and Ill be sure to give them a call to see if they can help me out. Looks like they can bend up U-bolts on request.
    Stuart
    Perth W.A.
    Stuee,
    What was the results on the U bolt fun and games??
    Andy
