Results 1 to 10 of 14
Thread: LIMP MODE CAN ANY ONE HELP PLZZZZZZ
    Sep 2011
    gippsland
    HI ALL JUST WONDERING IF ANYONE CAN HELP IVE HAD THIS INTER MITTEN PROBLEM WERE I CAN JUST BE DRIVING ALONG AND MY DISCO 2 SURGES A LITTLE THEN ALL OF A SUDDEN IT DOSE NOT HAVE ANY ACCELERATION IT IDLES ONLY COMPUTER DOSE NOT REGISTER ANY FAULTS AT ALL THE ENGINE LIGHT COMES ON WITH THE S & M MODE FLASHING AND ALSO THE RED LIGHT ON THE AUTOMATIC LEVER FLASH STOP AND START CAR AS NORMAL AND DRIVE OF IF ANY ONE HAS ANY IDEAS CAN YOU PLEASE HELP CHEERS
    Apr 2010
    South Melbourne
    Check your transmission inhibitor (XYZ) switch. There is a link in the Good Oil section of this forum for more info.
    Also check for oil at your engine ECU.
    Adelaide SA
    As Simon said, XYZ switch, oil in the harness, and then check all of the plugs for all of your ECU's to make sure none have worked their way loose.
    Don't forget the ones on the passenger side, on the side wall, hidden behind the cardboard kick panel.
    Mar 2011
    Sweden
    Greif
    Here you can find what I think is your problem in this thread.
    http://www.aulro.com/afvb/discovery-...-flashing.html
    I have more pictures if you need. cables rub and can short out on top.
    contact is the most likely cause of the problem moisture in the connector causing these problems , I believe that one should protect the cables as a preventive measure if it is not already a problem as it can be. a good site that explains it good is www.discovery2.co.uk
    Kingston, Tassie, OZ.
    Other possibility is the throttle potentiometer (Pedal assembly) this will usually illuminate the check engine lamp and result in no throttle activity at all, BUT it WILL register a driver demand error code, so possibly I am barking up the wrong tree here.
    JC
    I DON"T KNOW WHAT IT IS BUT DON"T PHONE ME 'CAUSE I WON'T HEAR YOU!
    99.87 MB
    Hey the other thing that I had recently trigger this was......
    Chaffed transmission wire loom!
    Slunnie
    Sep 2011
    gippsland
    THANKS GUYS FOR THE INFORMATION WILL TAKE A LOOK AT A FEW ITEMS OVER THE WEEK END WELL THANK FROM MOST PEOPLE ANY WAY THERE'S ALWAYS SOME ONE THAT'S A CLEVER DICK CHEERS AND ONCE AGAIN THANK YOU
    Feb 2011
    Brunswick, Victoria
    I'm sure you don't scream your conversations at the top of your lungs, so do us all a favor and quit with the ALL CAPS.
    All caps are difficult to read and the mark of an ill mannered and ignorant poster. I'm sure you don't want to be tarred with that brush.
    Sep 2011
    gippsland
    GET A ****ING LIFE HAVE SOME OF YOU GOT NOTHING BETTER TO DO all a bloke was asking for a few simple answers which i have sorted out thanks to a few people on here thank you very much
