Originally Posted by
Marty110
IMHO all defenders pull to the left slightly. My old 300Tdi pulled exactly the same to the left as my Puma. I am probably wrong but I reckon their chassis jigs are out a bit on the left side. I took my 300 to a chassis align place and they found that one side was marginally longer than the other and that was why they reckoned it pulled to the left, with little you could do about it. For the Puma I was told that the correction could only be made in the swivel hubs which would involve rebuilding brand new swivels - not an option I liked. So with both my defenders I fitted an RTC steering damper and loaded it up (just a little bit) to counter the left pull - takes a bit of trial and error and quite a few drives unless you are lucky enough to crack it first go! Got both my Deefers tracking spot on and with perfectly even tyre wear lucky enough!
