Results 1 to 10 of 11
Thread: Where's mi jack
    Aug 2012
    Where's mi jack
    So I have looked for the jack today and it’s nowhere to be seen, I checked the owner’s manual and it stated it is under the “left front seat”
    I look under the left front seat and can’t even find the mounting points where it would live according to the manual , it doesn’t even look like its ever been there .
    So I read further Ah! behind the front left seat , Nope!
    Once again read on Ah! under the back seat , Nope!
    So I’m at a loss where the heck is it ?
    Have you tried under the drivers seat
    Sent from my iPad using Tapatalk HD
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Aug 2012
    Quote Originally Posted by Reads90 View Post
    yep !
    Quote Originally Posted by Dockstrada View Post
    yep !
    Take it you have a 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Aug 2012
    Yep !
    Albury, NSW
    Guess you had best try under the rear seat
    And when you find it don't be surprised to see it came out of a Kellogg's Box - that is if it is the same as supplied to the previous model Defender (TD5).
    http://i271.photobucket.com/albums/j...KevsAvatar.jpg
    Defender '06 - (+ Tombie's Magic)
    Gone but not forgotten
    Defender 03 (Rolled)
    '99 TDI Discovery
    '96 V8 Discovery
    '86 V8 County (Life's regret selling this)
    Series III
    Well if you have looked under both front seats and under the back seats. You have also looked in the engine bay ( although doubt it will be there.)
    Then you don't have one. Surgest you buy one ;-)
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Aug 2012
    Quote Originally Posted by Barra1 View Post
    I had a look there , no luck .
    Feb 2010
    Sutherland Shire, Sydney
    The jacks on my 2010 and 2011 Defender 110s were in the battery compartment under the passenger seat, just forward of the battery. It may be obscured by a black bit of metal held down with a wing nut.
    If the jack isn't there then maybe the dealer still has it...
    While you're at it, did you find the adapter for the lock nuts on the wheel?
    Aug 2012
    Quote Originally Posted by RVR110 View Post
    From the sounds of it I don't think it's there , in any case it sound like it's not a great piece of engineering .
    I did find the lock nut adapter together with a plastic nut cap remover of some sort .
