Results 1 to 10 of 16
Thread: How to Tell a 6cyl Chassis from a 4cyl
    Mar 2012
    Porongurup Western Australia
    Hi all, I've been looking at my IIA and looking at the engine bay. It has a 4cyl engine but there's a couple of inches of clearance between the back of the engine and the bulkhead and the front crossmember is miles away from the engine and it has a lot of room between the sides of the engine.
    If anyone has some way of telling the difference between the two that'd be great.
    d@rk51d3 Guest
    Straight(ish) gearstick, or kinked?
    Gearboxes on the 6 had straight levers, the 4's were kinked.
    Firewall was different too.
    Doesn't directly answer your question about the chassis, but could point in a direction.
    Edit to add - Other than engine mounts, I didn't think there were any differences between the chassis.
    Somewhere else, QLD
    In the absence of others -
    this is a photo of my series III 6 cyl. I had started to convert it to v8 by cutting the 6 engine mounts and I was about to weld in v8 mounts.
    You can see where the 6 cyl mounts were on the right - about the same spot on the chassis as the shock mount. I was going to weld in the v8 mounts behind them - the flat area I hit with the grinder. The 4 cyl has mounts roughly in the same place ( you can drop a v8 into a 4cyl without having to mod the chassis)
    Mar 2012
    Quote Originally Posted by d@rk51d3 View Post
    Unfortunately my IIA didn't have a gearstick when I bought it so I got one of a 4cyl, can you describe what the firewall looks like.
    JDNSW's Avatar
    On the four, the gearbox crossmember is about 42" behind the centreline of the front axle, on the six it is about four inches further back (but the manual I have in front of me does not have the dimensions for the six).
    Thebulkhead for the four has the "engine bulge" about six inches forward of the instrument panel, the six has it only about two.
    Hope this helps.
    Sep 2006
    Northern Beaches
    Edit: Post deleted. JDNSW said the same before I hit go.
    Jeff
    East-South-East Girt-By-Sea
    1.20 MB
    A 6cyl SIII chassis will have a (943 or 948 SIII) prefix!
    A six cyl SIIa will have a 345, 346, 347, 348 or 349 prefix
    Last edited by Lotz-A-Landies; 30th August 2012 at 11:11 AM. Reason: correct SIII for SIIa 6cyl numbers
    Mar 2012
    Thanks for all the replies, I'll check the "engine bulge" tomorrow and let you know. I might also measure the distance between the gearbox crossmember and the centre line of the axle. The IIA's came in a 6cyl didn't they?
    JDNSW's Avatar
    Quote Originally Posted by Series3 GT View Post
    .... The IIA's came in a 6cyl didn't they?
    From 1967.
    Mar 2012
    Well my ones a 1970 any way so it could be, I didn't get time to check. Just read something interesting, someone said that a IIA six had a different grille. The grille they described as on that runs side to side. My IIA has this and it's been played around with before I bought it as in a different gearbox and a few other bits and pieces.
