I do not think simple would describe the task even though you hope not to be doing any of the electronics.
You would need a wrecked D3 so as to source all the air lines, the air tank, the compressor; the height sensors, the some electrical cable as well as the air springs, their mounting bits and who knows what else.
As to setting height, maybe you would ignore the height sensors and associated cables and just run an air line off each air spring and set visually one corner at a time.
Money wise, there is probably a better market for used coil spring D3's than used air suspension 3's. I think you could sell the coiler and buy an airing 3 and be money ahead. Also you would not have to purchase a wrecked air spring 3 either.
In other words, coil to air is not a common mode.
