Results 1 to 3 of 3
Thread: changing headlight switch
    May 2010
    Gisborne
    Hi all
    Just another quicky.
    My head light switch decided to give up the ghost.
    Just wondering if you just need to remove the steering wheel shroud or do you need to take steering wheel off like you do to change the blinkers & horn lever?
    I drive a td5 defender.
    Mick
    thompsonm Guest
    Smile head light switch
    hi you can take the shroud of with out removing the wheel but it is a lot easier with the wheel removed. Remove the rubber mat at the bottom of the shroud and then just undo the phillips screws.
    good luck !
    May 2010
    Gisborne
    Smile
    Thanks for that. Much appreciated.
