Results 1 to 10 of 39
Thread: The Solex B40 PA4IO-5a Carburetor thread!
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Anything and everything technical or helpful to the owners of the Solex B40 PAIO5 Carburetor as fitted to the series II and IIa land rover.
    Books, Articles, Links and whatever you can find that may be helpful!
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2008
    Bundaberg Qld
    May 2008
    Bundaberg Qld
    59SWB --------- sound familiar
    Print Page - Solex Carb Problems
    australia
    Quote Originally Posted by pop058 View Post
    hi popo going on s2 date 1959 solex at 350 dollors been on shelf a long time jim
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    I have two types of Solex B40 PA410-5a
    DSC_8952 by NiknoDave, on Flickr
    one with a venturi tube
    DSC_8958 by NiknoDave, on Flickr
    DSC_8955 by NiknoDave, on Flickr
    note the brass blank
    and one without
    DSC_8957 by NiknoDave, on Flickr
    DSC_8956 by NiknoDave, on Flickr
    note the brass jet
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    solex_mt_page1 by NiknoDave, on Flickr
    solex_mt_page2 by NiknoDave, on Flickr
    Attached Files Attached Files
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    what a brand new one looks like
    newsolex1 by NiknoDave, on Flickr
    newsolex2 by NiknoDave, on Flickr
    newsolex3 by NiknoDave, on Flickr
    newsolex4 by NiknoDave, on Flickr
    newsolex5 by NiknoDave, on Flickr
    courtesy of land lover treasure shop
    whom i purchased a second hand unit from. when it arrived here it was missing a jet or two and there were some other flaws i was less then impressed with.
    they replaced it with this.
    excellent service indeed! and i thank them kindly.
    Jun 2016
    Norway
    Strange tube on Solex carb
    Hi!
    I'm refurbishing a Solex 40PA10-5 carb for a 1964 Series II and noticed a strange copper tube near the inlet manifold flange. The previous owner has cut the tube and attempted to plug the stump with a piece of heat shrink tubing and a nail . See attached picture.
    Anyway, I can't find a single picture or reference that explains the purpose of this tube. Since I don't have access to the car myself, it's difficult to see what was connected at the other end.
    Any input would be appreciated.
    Br,
    Einar
    May 2003
    On The Road
    wow,, thats had a hard life!
    Nov 2014
    G'day Einar,
    The tube in the photo is part of the vacuum advance circuit.
    This tube goes to the vacuum advance diaphragm on the ignition distributor.
    It is important and necessary for the operation of the ignition system.
    The port in the Solex is a metric thread M6 x 1.00 and you use an olive on the tubing to seal the connection. The tubing is 0.125" (inch) diameter.
    The part number for the tube nut is 260707. They are made of steel and break often and probably you will have to make one out of hex stainless steel.
    Good luck
    Chris
    Last edited by Busted Syncro; 8th June 2016 at 01:10 PM. Reason: Metric thread size and part number for tube nut.
