                                                5th September 2012, 12:21 PM
			 Wiring through bulkhead??? Wiring through bulkhead???
					Has anyone got any ideas about how/where to route 12V cable through the bulkhead of a 2007 FL2 diesel?
 I've just about finished installing my Ham rig, pulled apart the dash and centre console without any major dramas, but getting the cable through to the battery has me stumped.
 Any ideas would be very welcome.
                                                5th September 2012, 12:46 PM
					Are there LH drive blanks in a Freelander?
 If so that is usually a good spot.
 Regards Philip A
                                                5th September 2012, 02:06 PM
					No blanks that I can see.
                                                6th September 2012, 03:43 AM
                                                #4
					Maybe you can pick up a 12v supply from under the dash; fuse?
                                                6th September 2012, 07:35 AM
                                                #5
					Problem is, I need a 25Amp supply. It has to come straight from the battery.
                                                6th September 2012, 04:21 PM
                                                #6
					Problem solved, Guys. Thanks to an old post on another forum, I followed their advice and traced the bonnet release lever through the bulk head and was able to feed coat hanger wire through. Only problem is, you have to remove the battery and battery tray to retrieve the cable. What a mission!
 Thanks for the advice from those who responded.
