Results 1 to 3 of 3
Thread: s3 109 5 door -- does canvas exist?
    dgaholmes Guest
    I've got a 75 109 s3 -- I want to canvas it, but have never seen one made for the 5 door. I'm thinking of cutting down a set of pre-made hoops (or bending from galvinized electrical conduit) -- but would love to know if anyone has a lead on a pattern or producer of the whole kit before I go headlong into it.
    While there were many different body styles produced in Series Landrovers, a canvas top five door is not one of them, although I have seen one conversion, and pictures of others.
    As you have probably realised, the roof abd sides behind the rear doors can be easily removed, but neither rear side doors nor the back door have removable tops. Standard hoops could be used at the back and probably at the back of the rear doors, but you would have to fabricate a hoop to join the B pillars. frames and seals for the door tops would have to be fabricated using the two door design as a guide. The back door will need to have a hinge added at the top of the lower body - a better idea may be to convert to a tailgate (pretty easy). The canvas would be a custom job, perhaps modifying a canvas for a two door.
    You may find it useful to get hold of the parts and optional parts books - probably the easiest way is to get the 'Rave CD' - see 'shop' on the bar at the top of this page.
    Hope this helps,
    Hi
    All Wheel Trim in the uk make them for 110 5 door. So take they will do it for a series land rover
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
