Results 1 to 10 of 19
Thread: series 1 panel layouts
    RIVERLAND, SOUTH AUSTRALIA
    Does anyone have a "blueprint" of the series 1 (80") front guards?
    I have a local bloke interested in making them but obviously it will be easier
    to get a quote if I can produce a plan, blueprint or measurements..
    Same for the rear tub sides/rear (I have the LRO article about making them from the recent mag)
    anyone able to help with a 'layout' and measurements of these or a point in the direction from which they can be obtained I really appreciate it.
    (would be made from aluminium and spot welded where appropriate etc)
    plan to get some plans
    Quote Originally Posted by digger View Post
    Wasn't there a complete set of Land Rover blue prints made and set out from the UK, when Australia started building and assembling?
    I wonder what has become of those?
    australia
    landrover 80 inch to 1957
    hi digger
    australia
    hi digger wadsworth panels make good repros i have aset here that somebody cut a light in the front panel as straight as you will get jim
    East-South-East Girt-By-Sea
    1.20 MB
    Hi Digger
    I want to concur with Jim about Wadsworth panels. Keith makes Series ones better than Land Rover made them in the 1940's and 1950s
    Personally I have found that getting a pair of the outer panels sent out is cost effective as they come boxed not much bigger than a single panel. The cost of getting inners and outers is expensive because of the lost space.
    Trying to press the complex curves of the outer panels would not be cost effective, however folding up the inner panels, doors and tub would be worthwhile. Allan H in Canberra has made a business of it for the 80", but won't do it in Winter because of the cold.
    Diana
    smurf village
    how much would a tub cost roughly?
    Loganlea Qld
    The outer skin on a series rover mudguard stayed the same from the early 80"s through to the end of the 86" production run (give or take a hole or two!).
    That should broaden the search considerably.
    When the 88"s came along then they added two inches to the front guards.
    The tops and inners do vary though.
    Glen
    1962 P5 3 Ltr Coupe (Gwennie)
    1963 2a gunbuggy 112-722 (Onslow) ex 6 RAR
    1964 2a 88" SWB 113 251 (Daisy) ex JTC
    REMLR 226
    1.20 MB
    Quote Originally Posted by schmierer LR at singleton View Post
    If you want one made roughly, you may as well go second hand!
    The price for a tub here is more than Aussies seem to be prepared to pay, the ones that Allan has made usually go to the UK. Doors are a different matter.
    Sep 2006
    Warragul
    Hi Digger
    Diana
    Yes I agree . Although with some thought and planning , I'd think it possible to fabricate the outer wing panels too , maybe you could TIG weld in that complex corner patch as a separate piece .
    The 80 tub would have to be one of the easiest bodies to make at home ... Compared to a WW2 Jeep with its steel and many curvy bits , a 80 tub would be a doddle in the park as its almost totally flat . Having seen the gems made out at Geelong road , gives one some confidence we can do it as well !
    Getting back to the question. To make templates , you use the old panel and flatten it out , you then use that flattened out panel to mark out the new panel and you have the exact size to cut out , the aircraft restorers use that method MIKE
    I tried to get a website for wadsworth panels, well, he obviously doesnt need to get people via the web (a very unhappy experience!)
    "panels made down geelong road" ???? Ke? do tell.
