Results 1 to 10 of 17
Thread: MAF sensor issue?
    Oct 2007
    Williamstown, Victoria
    MAF sensor issue?
    Hi everyone, was driving my 2001 HSE 4.6 up the Westgate the other night and noticed the engine hesitating under load, felt a bit like not enough fuel being delivered.
    It was fine from a standing start, but the idle was slightly rough.
    From my past experience with classic Rangies, I gave the throttle body a good clean out and also cleaned the contacts on the maf sensor plug.
    Hey presto, running much better, idle perfect, no more hesitating under load.
    Tonight the same problem returned, I'm guessing it must be something to do with the maf sensor.
    Does anyone have any tips as to how to tackle this problem?
    Can they be cleaned, or is it time for a new one?
    Cheers, Pete.
    Spraying the sensor with Carburettor cleaner or non-residue disc brake cleaner often gets rid of any stuff which may have collected on the MAF
    It may also be an electrical issue with the spark breaking down under load...have you checked the plugs/ignition leads and coil block? I'd also be checking all earth points....
    Jun 2012
    I would also check the fuel pressure at the fuel rail. If possible connect it to the fuel rail and take it for a drive and see if there is sufficient pressure.
    Oct 2007
    Thanks for the replies.
    I usually suspect the sensor with these type of problems before looking deeper.
    I've never had to play around with the maf sensor before though.
    Is it safe to spray the sensor with carby cleaner?
    Dec 2009
    Tyrendarra Vic (South West Vic )
    You can buy proper MAF sensor cleaner. Got some for my P38 when I owned it . Most good auto shops should have it
    Gary
    Feb 2010
    CRC Branded "MAF Sensor Cleaner".
    A left field worst case scenario... carbon fouling of valve stems
    http://www.robisonservice.com/servic...n_fouling1.pdf
    http://www.robisonservice.com/servic...n_fouling2.pdf
    It's worth a read...even if to positively rule it out as a cause...
    Oct 2007
    Thanks fellas, I'll try the maf sensor cleaner, sounds like a much easier start than pulling the heads off! I'm away for a couple of weeks, will do that when I get back and let you know the results. I hope that's all it is.
    Cheers, Pete.
    May 2008
    I just use Isopropyl Alcohol from JayCar to clean mine... think it was someone here that recommended it a few years ago.
    Is it any better or worse than MAF Cleaner?
    Oct 2007
    Bit of an update for you, I tried the crc maf sensor cleaner, now running much smoother.
    It's probably one of those things that gradually gets worse over time, so you don't really notice it until it gets bad enough.
    What a difference, the idle is perfect, runs beautifully.
    Still noticing some hesitation accelerating uphill though.
    Will have to check the ignition leads next I guess.
    Cheers, Pete.
