It's not 100% compatible with the Hema maps. The map projections Hema use aren't supported. This is the result of the library which provides .ozf2 support being written by a European, and support for Australian map projections weren't considered important.
The maps will load but they are align to longitude and latitude rather then grid the maps were projected on. This results in a variable position errors across map sheets.
Ozf3 is not supported, nor is ECW.
Androzic, Bit Map, Multiplans, GDAL etc all suffer from this issue.
