Welcome to AULRO.
2 quick thoughts..
1/
How easy is it to swap the power feed for the existing anderson plug to the second battery instead of the starting one?
2/
As an option could you make a lead up?
Tempory mount a new anderson plug in the rear and run the cable out/under to the rear.
When the battery comes out of the camper plug the above lead to the exisiting anderson plug and the battery to the plug inside.
It's all charging as it does in the camper then and easily removed at home afterwards.
Cheers, Kyle.
