Have you checked that with a GPS on a level long stretch?
I found by going to oversize tyres my speedo was more correct!
With changing from the OEM 255/55R18 F1 tyres to 255/60R18 GG ATs my speedo now reads on the wrong side of being correct. Now reads 100kph when actually doing 104kph - doesn't sound much but enough to get pinged by the boys in blue when you think you are on the limit.
Is there anyway on the D3/RRS I can get the speedo corrected.
garry
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
 Master
						Master
						None that I am aware of. At work we can only adjust the rim size, not the profile size. There are aftermarket products that you can use to alter it, however I don't recommend it, as it is very tricky to do and will void your warranty for some parts of your car.
The best thing you can do is either use a gps speedo OR just remember that your speedo is a bit off and adjust your driving style ocordingly.
There may be other way but none that I am aware of. Happy driving!
I really think your speedo should be more accurate!
Garry, mine is almost exactly the same over read as yours, I've gone from the OEM 255/50/19 to the D3 size, 255/55/19. 100km/h is 103 according to my gps & the speed checker on the motorway over near Geelong
Cost me my 1st Aussie speeding ticket on my return from the UK at the weekend
 Swaggie
						Swaggie
						I corrected my D4's speedo for my current tyres using Faultmate but there are several places in the D4 CCF where changes have to be made to keep the speedometer, odometer and cruise control speed syncronised if the change is going to be done properly. It includes converting the tyre's dynamic rolling radius in mm to 2 bytes of hex values as the most and least significant byte values for use by the odometer. I understand that the D4 CCF is quite different to the CCF in pre-MY10 D3/RRS.
The factory speedometer calibration setting of 3.5% + 2 kph (if the same as the D4) should make your speedo about right with the larger tyres although the odometer will show slightly less distance than actual.
This reflects my experience with my GPS vs Speedo - I read 104kph this calculator says 103.34kph.
When I had my scangauge connected I could adjust it to get the correct speed - I figured the same might be able to be done via a Faultmate or Nanocom. However the cars computer only displays basic information even though the OBD2 system has many more inputs which the scangauge can read but the scanguage died with a lightning strike late last year and I have not replaced it.
