Leaking head welch plug & missing manifold studs
So we all know about it ... don't we ?
Mine's had a tiny leak for a while. Looked everywhere else, that I could, and couldn't find ant evidence of another leak.
Disco's been parked up for months on end since Mrs F got the new Impreza. Since using it over the last few weeks the coolant leak seems to have gotten worse (a little), and since I knew everything was OK except the welch plug, the one thing I couldn't confirm was the heater hose to oil cooler little short tapered hose under the turbo sheild, that you can't see
Decided to whip the turbo & manifold heat sheilds off to inspect said hose, only to find the hose is in good nick, still soft & pliable .... but it appears the welch plug has gotten worse
God that red OAT makes a stinking filthy mess ... (and notice no5 lower manifold stud ... is there)
So, as a temp measure (cause I'm not pulling the manifold just yet) I was able to drift the welch plug about 1/2-3/4 of turn. Hopefully that slows it down so I can get over the next two weeks Belanglo & CBG .... running the raditor cap loose will stop it from pressurizing.
Strange ... on short around town runs, it leaks ... on long runs it stops leaking (with the tank cap sealed off and the cooling system pressurized).
So while I'm in there, I notice that no1 upper exhaust manifold stud is missing ... figures!
It's squeeled once or twice on full boot, so I knew exactly what that meant ..... nut's gone, along with stud, with balance of stud still in head ... sigh ...
Looks like it's been gone for a long time ... but only minor carbon traces evident.
So I figure the best bet is to check all the other studs ... bar one or two I couldn't get to easily .... they're all good EXCEPT no5 lower just sheers off like a pretzel .... BIG sigh .... looks like the stud is still there just inside the hole ... didn't breake clean against the head like no1 has.
Hhmmm ...... a bit more evidence of carbon traces around that port. That said, it only squeels if I give it an absolute kick in the goolies. Top one end, bottom the other ... twisted ?
So I'll order another hose while it's apart and replace it, just for good measure ... and the welch plug and manifold can live like it is for a while longer, 'cause that's going to be a much bigger job
Thank god for the trusty Engine Saver!
But, everything I need to know AULRO has already provided me ... just gotta dig in and do it!
BTW - 2 x 8mm studs to remove on the exhuast manifold heat sheild, and the rear one in the turbo heat sheild ... why the **** did they make that 10mm ???? I spent 20min tring to get an 8mm socket on to it ...
Kev..
2014 Isuzu MUX LST with fruit
2008 Isuzu D-Max
2015 Kimberley Kamper "Classic"
Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
