What size motor is in the D4? I suspect that will influence the response.
 Fossicker
						Fossicker
						Hi Guys, I'm needing to do the rotors on all four corners of my wifes 2009 Disco 4 and I'm wanting to replace with the DBA T2 rotor on the fronts first.
In the parts catalog there is only mention of RR Sport III and D3 with the same part no. of 2090S for the fronts but says part not found for the D4.
Did the rotor at all change from the D3 to D4 and has anyone done the T2 on theres?
What other non-OEM options would you recommend?
Calis
 Fossicker
						Fossicker
						Ahh yes I should have mentioned that thanks jonesy.
2.7 TDV6
Calis - a quick search shows D4 2.7 front rotor part numbers are:
SDB000604, SDB000603 - the same as D3 2.7.
FWIW, I have used the slotted DBA rotors in my XR6 Falcon and they are a good upgrade for that application. It would be good to hear from anyone that has installed them on a D3 or D4.
 Fossicker
						Fossicker
						thanks jonesy. i have seen these ones also.
Called DBA today and as excepted there is no particular item for the T2 for the D4. They suggested I get the D4 rotor dimensions which I will try and find so they can double check fitment.
Assuming parts SDB000604, SDB000603 fit both the D3 & 4 it could be assumed the D3 DBA part could work on the D4.
All assumptions of course!
 ChatterBox
						ChatterBox
						There are a few different sizes for the D3/4:
2.7L D3/D4
V8 D3
V8 D3 Brembo
3.0L D/4
 Fossicker
						Fossicker
						yep so in this case we are talking D3 2.7 to D4 2.7 size similarity/compatibility
Calis,
I replaced my rotors on my D4 (3 ltr) recently. Fitted DBAs but had them do a custom job to make them slotted, which was done by DBA for me. Took about 2 weeks for them to be done. Happy with the results. Can't remember the price. Will see if I can find the receipt.
Cameron
If in doubt, throttle out
MY16 RRS SE SDv6
MY16 Ranger XLT
2008 911 GT2 - dream came true
1976 Escort mk2 - race car
