Originally Posted by
Spel1
Sumo. My 300TDI was losing water too, was only using plain water at the time so couldn't find the leak. Switched to coolant, just the cheaper premixed one. Couldn't see anything on the side from the P gasket or from the hoses, but a few weeks later spotted green streaks under the water pump pulley, so replaced the pump and the P gasket. (I will never again replace a water pump without this, just wasting time from previous experience). Strange though, coolant was not leaking from the weep hole but from a tiny crack in the pump body just under the bolt that holds the top heater hose bracket, never seen this before - no erosion just cracked. Wasn't a cheapy either, OEM - just one of those castings I guess. Wasn't until using coolant that it was easily visible.
One other thing though, I was losing significant coolant previously, about what you are losing - so went ahead and replaced the head gasket. It was a composite one and was showing signs of water tracking towards the cylinders. Replaced with the same 3 hole gasket but in stainless steel, head was not warped so decided to just bolt it back on and see how it went, which is why I was just running water to test it. Its been a tedious search but I think am finally getting on top of it.
Good luck with tracking down the leak. Simon
