It depends.
As best I can determine the TC does lock up at about 60kmh with only a light load on the transmission. For example, heading along a straight, flat section of road.
We have a very steep hill close to home here and while the transmission will sit in third, TC unlocked, and reasonably high rpm (2500+) while climbing as soon as I level out it shifts up to fifth and locks up the TC. It's a 60kmh zone that drops fairly soon to a 40kmh school zone depending on time of day. Even in manual mode it doesn't seem to be coerced into behaving differently.
I find on the highway it locks the TC at around 80kmh (or perhaps a smidge over) and is reluctant to unlock unless provoked i.e. hard throttle press - kickdown scenario.
Between 60kmh and 80kmh seems to be a grey area. The TC can lock but may not depending on style/activity. Beyond 80kmh it definitely locks up. Below 60kmh it will not lock up.
I haven't found anything that suggests that this can be programmed differently. This, like lots of transmission stuff, is influenced by inputs from lots of other ECUs about the car so is setup that way to provide the most generic solution IMHO.
Hope that helps some Jim.
Iain
Iain
VK3BIT
03MY Range Rover HSE Td6
Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
LROCV DTU member
