Results 1 to 10 of 31
Thread: TD5 MAF Stuffed?
    Perth WA 6149
    TD5 MAF Stuffed?
    Hi All
    I have been having a very occasional bout of sluggishness when I first start off in my 2003 D2a. After about 10-20 seconds it disappears and all is fine. Only occurs once a week or so and only when starting from cold. Inter-cooler hoses and fuel regulator have recently been replaced.
    I got a Nancom recently and decided to plug it and see what I could find.
    Anyway long story short there were no engine faults logged, but went for a drive and the Airflow failed to budge from a reading of 4.3. So I let everything cool down, removed the MAF and gave it a good cleaning with contact cleaner, let it dry and reinstalled. Did another test run and still a flat line reading of 4.3. Nanocom log for the first run is attached for those who are interested.
    Searching the forum it appears I should be getting about 50ish at idle up to a max of 500ish. So would I be correct is saying I'm up for a new MAF sensor or should I be looking a bit deeper?
    Steve
    Attached Files Attached Files
    Check your fuse, and the wire running to the MAF...
    Slunnie knows exactly which fuse it is...
    Even an out of range MAF should be reading something...
    Anyone nearby you know - try their MAF
    Jul 2011
    Yarrawonga, Vic
    well bugger me,
    i didnt know you could save a log like that on the nanocom.
    very handy. how do you do it ?
    Perth WA 6149
    Thanks tombie
    I did check the fuse (no 2 under the bonnet) and wiring looks ok, anything in particular I should be looking for there? I also gave the connector a clean, before plugging in again.
    Goingbush I don't have the nanocom powered up so from memory.... at the bottom of the instrument read out screen towards the right side is a blue disk icon. Tap that and it goes to a file screen. Tap in a file name hit ok and ok again and logging starts. Tap the same icon again to stop logging and the nanocom will give an alert that the logging has stopped. You need to have an SD card inserted though. Plug the Sd card into your computer and you can open the file in excel. Note it is not a true csv file as it uses semicolons instead of comas as a delimiter but you can easily spread break it up into columns by selecting the data and using the text to columns command.
    Steve
    JC Rover Guest
    I ran the Nanocom on the defender TD5 with MAF unplugged by accident. The Nanocom read air flow constantly as 4.0.
    Strange, it also ran a lot better. The MAF had been reading low. I will try cleaning it, and then perhaps replace it.
    JC
    Jun 2010
    Bayswater, Western Australia
    Hi Steve,
    I have a spare MAF that you are welcome to try. It is from my V8 but IIRC they are the same on the TD5.
    We met a few weeks ago at LifeStyle 4x4 and I'm not too far from there. I'm also home all next week resting my shoulder...
    Ron
    Perth WA 6149
    Thanks Ron, the offer is much appreciated. Yep I remember you and your tidy silver/grey d2
    I just had a quick check on the Russian Microcat site and unfortunately the td5 and v8 MAF sensors have different part numbers and in the schematics look different as well. So it probably won't help in conclusively diagnosing the problem.
    Good luck with the shoulder. I'm hoping to get away to Mt Jackson on the weekend with the club. Thankfully the sensor problem isn't a show stopper, and the car is running well.
    JC thanks for your observation. I'll try running it unplugged and see if my readings change.
    Steve
    Melbourne, Australia
    Quote Originally Posted by RSCHIPP View Post
    Hi Steve,
    Ron
    Are they the same? I was under the impression that the V8 has a different MAF. They are also cheaper than the Td5 MAF.
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by Rok_Dr View Post
    Talk about doing the hard way.
    In excel use Import > CSV File rather than open.
    The import wizard allows you to select semicolons as the delimiter.
    If you want to make life even easier got to td5 map suite
    and grab a copy of Graphic Viewer CSV (at the bottom of the page).
    Jun 2010
    Quote Originally Posted by Franz View Post
    Hi Franz,
    You are correct, they are indeed different. The V8 MAF has a 5 pin connection and the TD5 appears to only have a 3 pin connection. I was under the impression that they were the same after looking under the bonnet of a few TD5s but sadly not to be. Sorry for the miss info...
    Ron
